I am trying to install caffe, but ran into the following error
sudo apt-get install caffe-cpu
[sudo] password for :
Reading package lists... Done
Building dependency tree
E: Unable to locate package caffe-cpu
This is my version:
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 16.04.4 LTS
Release: 16.04
Codename: xenial
I tried following the instructions here https://chunml.github.io/ChunML.github.io/project/Installing-Caffe-CPU-Only/
Got
CXX src/caffe/test/test_hdf5_output_layer.cpp
In file included from src/caffe/test/test_hdf5_output_layer.cpp:8:0:
./include/caffe/layers/hdf5_output_layer.hpp:4:18: fatal error: hdf5.h: No such file or directory
compilation terminated.
Makefile:581: recipe for target '.build_release/src/caffe/test/test_hdf5_output_layer.o' failed
make: *** [.build_release/src/caffe/test/test_hdf5_output_layer.o] Error 1
This is what I have
ThinkPad-T520:/usr/lib/x86_64-linux-gnu$ ls -al | grep libhdf5_serial
lrwxrwxrwx 1 root root 53 Jul 19 10:03 libhdf5_hl.so -> /usr/lib/x86_64-linux-gnu/libhdf5_serial_hl.so.10.0.2
-rw-r--r-- 1 root root 19953086 Apr 5 2016 libhdf5_serial.a
-rw-r--r-- 1 root root 1659560 Apr 5 2016 libhdf5_serial_fortran.a
lrwxrwxrwx 1 root root 32 Apr 5 2016 libhdf5_serial_fortran.so -> libhdf5_serial_fortran.so.10.0.2
lrwxrwxrwx 1 root root 32 Apr 5 2016 libhdf5_serial_fortran.so.10 -> libhdf5_serial_fortran.so.10.0.2
-rw-r--r-- 1 root root 238408 Apr 5 2016 libhdf5_serial_fortran.so.10.0.2
-rw-r--r-- 1 root root 878832 Apr 5 2016 libhdf5_serial_hl.a
-rw-r--r-- 1 root root 515320 Apr 5 2016 libhdf5_serialhl_fortran.a
lrwxrwxrwx 1 root root 34 Apr 5 2016 libhdf5_serialhl_fortran.so -> libhdf5_serialhl_fortran.so.10.0.2
lrwxrwxrwx 1 root root 34 Apr 5 2016 libhdf5_serialhl_fortran.so.10 -> libhdf5_serialhl_fortran.so.10.0.2
-rw-r--r-- 1 root root 80520 Apr 5 2016 libhdf5_serialhl_fortran.so.10.0.2
lrwxrwxrwx 1 root root 27 Apr 5 2016 libhdf5_serial_hl.so -> libhdf5_serial_hl.so.10.0.2
lrwxrwxrwx 1 root root 27 Apr 5 2016 libhdf5_serial_hl.so.10 -> libhdf5_serial_hl.so.10.0.2
-rw-r--r-- 1 root root 126232 Apr 5 2016 libhdf5_serial_hl.so.10.0.2
-rw-r--r-- 1 root root 3859 Apr 5 2016 libhdf5_serial.settings
lrwxrwxrwx 1 root root 24 Apr 5 2016 libhdf5_serial.so -> libhdf5_serial.so.10.1.0
lrwxrwxrwx 1 root root 24 Apr 5 2016 libhdf5_serial.so.10 -> libhdf5_serial.so.10.1.0
-rw-r--r-- 1 root root 2734288 Apr 5 2016 libhdf5_serial.so.10.1.0
lrwxrwxrwx 1 root root 50 Jul 19 10:03 libhdf5.so -> /usr/lib/x86_64-linux-gnu/libhdf5_serial.so.10.1.0
After making changes to Makefine.config, getting
CXX src/caffe/util/hdf5.cpp
CXX src/caffe/util/benchmark.cpp
CXX src/caffe/internal_thread.cpp
CXX src/caffe/layer.cpp
CXX src/caffe/layer_factory.cpp
LD -o .build_release/lib/libcaffe.so.1.0.0
/usr/bin/ld: cannot find -lopencv_imgcodecs
/usr/bin/ld: cannot find -lcblas
/usr/bin/ld: cannot find -latlas
collect2: error: ld returned 1 exit status
Makefile:572: recipe for target '.build_release/lib/libcaffe.so.1.0.0' failed
make: *** [.build_release/lib/libcaffe.so.1.0.0] Error 1
