So i looked through the posts here and i found this helpful advice: Manually turn off monitor
I assigned a hotkey to turn my monitor off with the following code:
sleep 0.3 && xset dpms force off
However i was wondering if there is an easy way to keep the monitor off until the exact same shortcut is pressed. I usually turn off the monitor to save up some battery life and every little movement turns it back on (accidental key press, mouse move, or a touch pad contact).
Thanks for helping
Aqua-
  • 67
In Ubuntu 18.04, dpms not working properly with GNOME Wayland
$ xset -q
DPMS (Energy Star):
Display is not capable of DPMS
You can try the command below,
to turn off monitor:
busctl --user set-property org.gnome.Mutter.DisplayConfig /org/gnome/Mutter/DisplayConfig org.gnome.Mutter.DisplayConfig PowerSaveMode i 1
To turn on monitor:
busctl --user set-property org.gnome.Mutter.DisplayConfig /org/gnome/Mutter/DisplayConfig org.gnome.Mutter.DisplayConfig PowerSaveMode i 0
It works for me.
(Link)
eR_
  • 190
