Errors:
Reading package lists... Done
Building dependency tree
The following additional packages will be installed:
  aptitude-common libcwidget3v5
Suggested packages:
  aptitude-doc-en | aptitude-doc apt-xapian-index debtags tasksel
  libcwidget-dev
The following NEW packages will be installed:
  aptitude aptitude-common libcwidget3v5
0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
24 not fully installed or removed.
Need to get 2,571 kB of archives.
After this operation, 10.9 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Get:1 http://archive.ubuntu.com/ubuntu artful/main amd64 aptitude-common all 0.8.3-1ubuntu4 [835 kB]
Get:2 http://archive.ubuntu.com/ubuntu artful/main amd64 libcwidget3v5 amd64 0.5.17-6 [291 kB]
Get:3 http://archive.ubuntu.com/ubuntu artful/main amd64 aptitude amd64 0.8.3-1ubuntu4 [1,446 kB]
Fetched 2,571 kB in 37s (68.1 kB/s)
Selecting previously unselected package aptitude-common.
(Reading database ... 204973 files and directories currently installed.)
Preparing to unpack .../aptitude-common_0.8.3-1ubuntu4_all.deb ...
Unpacking aptitude-common (0.8.3-1ubuntu4) ...
Selecting previously unselected package libcwidget3v5:amd64.
Preparing to unpack .../libcwidget3v5_0.5.17-6_amd64.deb ...
Unpacking libcwidget3v5:amd64 (0.5.17-6) ...
Selecting previously unselected package aptitude.
Preparing to unpack .../aptitude_0.8.3-1ubuntu4_amd64.deb ...
Unpacking aptitude (0.8.3-1ubuntu4) ...
Setting up oracle-java8-installer (8u171-1~webupd8~1) ...
Using wget settings from /var/cache/oracle-jdk8-installer/wgetrc
Downloading Oracle Java 8...
--2018-07-15 21:14:16--  http://download.oracle.com/otn-pub/java/jdk/8u171-b11/512cd62ec5174c3487ac17c61aaa89e8/jdk-8u171-linux-x64.tar.gz
Resolving download.oracle.com (download.oracle.com)... 104.108.220.248
Connecting to download.oracle.com (download.oracle.com)|104.108.220.248|:80... connected.
HTTP request sent, awaiting response... 302 Moved Temporarily
Location: https://edelivery.oracle.com/otn-pub/java/jdk/8u171-b11/512cd62ec5174c3487ac17c61aaa89e8/jdk-8u171-linux-x64.tar.gz [following]
--2018-07-15 21:14:20--  https://edelivery.oracle.com/otn-pub/java/jdk/8u171-b11/512cd62ec5174c3487ac17c61aaa89e8/jdk-8u171-linux-x64.tar.gz
Resolving edelivery.oracle.com (edelivery.oracle.com)... 104.108.155.19, 2600:1417:2c:1a4::2d3e, 2600:1417:2c:19f::2d3e
Connecting to edelivery.oracle.com (edelivery.oracle.com)|104.108.155.19|:443... connected.
Location: http://download.oracle.com/otn-pub/java/jdk/8u171-b11/512cd62ec5174c3487ac17c61aaa89e8/jdk-8u171-linux-x64.tar.gz?AuthParam=1531669582_b3ee47aaa0fcebe9ede7165ae628e7e9 [following]
--2018-07-15 21:14:22--  http://download.oracle.com/otn-pub/java/jdk/8u171-b11/512cd62ec5174c3487ac17c61aaa89e8/jdk-8u171-linux-x64.tar.gz?AuthParam=1531669582_b3ee47aaa0fcebe9ede7165ae628e7e9
HTTP request sent, awaiting response... 416 Requested Range Not Satisfiable
    The file is already fully retrieved; nothing to do.
Download done.
Removing outdated cached downloads...
sha256sum mismatch jdk-8u171-linux-x64.tar.gz
Oracle JDK 8 is NOT installed.
dpkg: error processing package oracle-java8-installer (--configure):
 subprocess installed post-installation script returned error exit status 1
Setting up aptitude-common (0.8.3-1ubuntu4) ...
Processing triggers for libc-bin (2.26-0ubuntu2.1) ...
dpkg: dependency problems prevent configuration of libgeronimo-jms-1.1-spec-java:
 libgeronimo-jms-1.1-spec-java depends on default-jre-headless | java5-runtime-headless; however:
  Package default-jre-headless is not installed.
  Package oracle-java8-installer which provides default-jre-headless is not configured yet.
  Package java5-runtime-headless is not installed.
  Package oracle-java8-installer which provides java5-runtime-headless is not configured yet.
dpkg: error processing package libgeronimo-jms-1.1-spec-java (--configure):
 dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
                          dpkg: dependency problems prevent configuration of ant:
 ant depends on default-jre-headless | java5-runtime-headless | java6-runtime-headless | java7-runtime-headless; however:
  Package java6-runtime-headless is not installed.
  Package oracle-java8-installer which provides java6-runtime-headless is not configured yet.
  Package java7-runtime-headless is not installed.
  Package oracle-java8-installer which provides java7-runtime-headless is not configured yet.
dpkg: error processing package ant (--configure):
                          dpkg: dependency problems prevent configuration of javahelp2:
 javahelp2 depends on default-jre | java2-runtime; however:
  Package default-jre is not installed.
  Package oracle-java8-installer which provides default-jre is not configured yet.
  Package java2-runtime is not installed.
  Package oracle-java8-installer which provides java2-runtime is not configured yet.
dpkg: error processing package javahelp2 (--configure):
No apport report written because MaxReports is reached already
                                                              dpkg: dependency problems prevent configuration of bnd:
 bnd depends on default-jre-headless | java6-runtime-headless; however:
dpkg: error processing package bnd (--configure):
                                                              dpkg: dependency problems prevent configuration of junit4:
 junit4 depends on default-jre-headless | java5-runtime-headless; however:
dpkg: error processing package junit4 (--configure):
                                                              dpkg: dependency problems prevent configuration of libistack-commons-java:
 libistack-commons-java depends on ant; however:
  Package ant is not configured yet.
dpkg: error processing package libistack-commons-java (--configure):
                                                              dpkg: dependency problems prevent configuration of libnb-java5-java:
 libnb-java5-java depends on ant; however:
dpkg: error processing package libnb-java5-java (--configure):
                                                              Processing triggers for man-db (2.7.6.1-2) ...
dpkg: dependency problems prevent configuration of aspectj:
 aspectj depends on default-jre-headless | java7-runtime-headless; however:
dpkg: error processing package aspectj (--configure):
Setting up libcwidget3v5:amd64 (0.5.17-6) ...
                                                              dpkg: dependency problems prevent configuration of antlr3:
 antlr3 depends on default-jre-headless | java5-runtime-headless | java6-runtime-headless; however:
dpkg: error processing package antlr3 (--configure):
                                            dpkg: dependency problems prevent configuration of netbeans:
 netbeans depends on default-jdk (>= 2:1.8) | java8-sdk; however:
  Package default-jdk is not installed.
  Package java8-sdk is not installed.
  Package oracle-java8-installer which provides java8-sdk is not configured yet.
 netbeans depends on libnb-java5-java (= 8.1+dfsg3-4); however:
  Package libnb-java5-java is not configured yet.
dpkg: error processing package netbeans (--configure):
dpkg: dependency problems prevent configuration of libcodemodel-java:
 libcodemodel-java depends on libistack-commons-java; however:
  Package libistack-commons-java is not configured yet.
dpkg: error processing package libcodemodel-java (--configure):
                                                              dpkg: dependency problems prevent configuration of libnb-platform18-java:
 libnb-platform18-java depends on antlr3 (>= 3.4); however:
  Package antlr3 is not configured yet.
 libnb-platform18-java depends on javahelp2; however:
  Package javahelp2 is not configured yet.
 libnb-platform18-java depends on junit4 (>= 4.6); however:
  Package junit4 is not configured yet.
dpkg: error processing package libnb-platform18-java (--configure):
                                                              dpkg: dependency problems prevent configuration of libsvnkit-java:
 libsvnkit-java depends on antlr3; however:
dpkg: error processing package libsvnkit-java (--configure):
                                                              dpkg: dependency problems prevent configuration of libnb-apisupport3-java:
 libnb-apisupport3-java depends on libnb-java5-java (= 8.1+dfsg3-4); however:
 libnb-apisupport3-java depends on libnb-platform18-java (>= 8.1); however:
  Package libnb-platform18-java is not configured yet.
dpkg: error processing package libnb-apisupport3-java (--configure):
                                                              dpkg: dependency problems prevent configuration of libjaxb-java:
 libjaxb-java depends on libcodemodel-java (>= 2.6+jaxb2.3.0-1); however:
  Package libcodemodel-java is not configured yet.
 libjaxb-java depends on libistack-commons-java (>= 2.17); however:
dpkg: error processing package libjaxb-java (--configure):
                                            dpkg: dependency problems prevent configuration of ant-optional:
 ant-optional depends on ant (= 1.9.9-4); however:
dpkg: error processing package ant-optional (--configure):
dpkg: dependency problems prevent configuration of libbindex-java:
 libbindex-java depends on ant; however:
 libbindex-java depends on bnd; however:
  Package bnd is not configured yet.
 libbindex-java depends on junit4; however:
dpkg: error processing package libbindex-java (--configure):
                                                              dpkg: dependency problems prevent configuration of libnb-platform-devel-java:
 libnb-platform-devel-java depends on ant; however:
 libnb-platform-devel-java depends on javahelp2; however:
 libnb-platform-devel-java depends on libbindex-java; however:
  Package libbindex-java is not configured yet.
 libnb-platform-devel-java depends on libnb-platform18-java (>= 8.1+dfsg1-6); however:
dpkg: error processing package libnb-platform-devel-java (--configure):
                                                              dpkg: dependency problems prevent configuration of libeclipselink-java:
 libeclipselink-java depends on antlr3 (>= 3.2); however:
 libeclipselink-java depends on libgeronimo-jms-1.1-spec-java; however:
  Package libgeronimo-jms-1.1-spec-java is not configured yet.
dpkg: error processing package libeclipselink-java (--configure):
                                                              Setting up aptitude (0.8.3-1ubuntu4) ...
update-alternatives: using /usr/bin/aptitude-curses to provide /usr/bin/aptitude (aptitude) in auto mode
dpkg: dependency problems prevent configuration of libtxw2-java:
 libtxw2-java depends on libcodemodel-java (>= 2.6+jaxb2.3.0-1); however:
dpkg: error processing package libtxw2-java (--configure):
                                            dpkg: dependency problems prevent configuration of libmsv-java:
 libmsv-java depends on ant; however:
dpkg: error processing package libmsv-java (--configure):
dpkg: dependency problems prevent configuration of libnb-ide14-java:
 libnb-ide14-java depends on antlr3 (>= 3.5.2); however:
 libnb-ide14-java depends on libjaxb-java; however:
  Package libjaxb-java is not configured yet.
 libnb-ide14-java depends on libnb-platform18-java (>= 8.1); however:
 libnb-ide14-java depends on libsvnkit-java; however:
  Package libsvnkit-java is not configured yet.
dpkg: error processing package libnb-ide14-java (--configure):
                                                              dpkg: dependency problems prevent configuration of libsqljet-java:
 libsqljet-java depends on antlr3; however:
dpkg: error processing package libsqljet-java (--configure):
 ant
 javahelp2
 bnd
 junit4
 libnb-java5-java
 aspectj
 antlr3
 netbeans
 libcodemodel-java
 libsvnkit-java
 libjaxb-java
 ant-optional
 libbindex-java
 libeclipselink-java
 libtxw2-java
 libmsv-java
 libnb-ide14-java
 libsqljet-java
well i'm new at Ubuntu and don't know how to resolve them..
Shivam
First command is worth to run:
sudo dpkg --configure -a
Then step by step:
sudo apt autoclean
sudo apt clean
sudo rm /var/lib/apt/lists/* -vf
sudo apt update
sudo apt upgrade
Finally install everything you want using apt.
UPDATE
Additionally try:
sudo rm -rf /var/lib/dpkg/info/oracle-java8-installer*
sudo apt purge oracle-java8-installer*
sudo rm -rf /etc/apt/sources.list.d/*java*
sudo apt update
sudo add-apt-repository ppa:webupd8team/java
sudo apt update
sudo apt install oracle-java8-installer
Bob
  • 2,563
