I'm getting the following error when running pretty much every apt-get command:
You might want to run 'apt-get -f install' to correct these:
linux-headers-3.13.0-153-generic : Depends: linux-headers-3.13.0-153 but it is not going to be installed
I do not have enough space to run apt-get -f install (or -f autoremove) as suggested:
Unpacking linux-headers-3.13.0-153 (3.13.0-153.203) ...
dpkg: error processing archive /var/cache/apt/archives/linux-headers-3.13.0-153_3.13.0-153.203_all.deb (--unpack):
unable to create `/usr/src/linux-headers-3.13.0-153/include/linux/lapb.h.dpkg-new' (while processing `./usr/src/linux-headers-3.13.0-153/include/linux/lapb.h'): No space left on device
No apport report written because the error message indicates a disk full error
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
And I cannot remove/purge linux-headers-3.13.0-153-generic because linux-headers-generic depends on it. Even though I'm botting from another version:
$ uname -r
3.13.0-141-generic
So, I'm pretty much stuck here. I've seen other questions like this but answers are usually to remove/purge old kernels. I cannot purge/remove old kernels as it gives an error like in the first snippet.
- How can I remove 3.13.0-153 related packages?
- Is there an alternative way to safely remove packages to free up space?
Edit
$ df -h
Filesystem Size Used Avail Use% Mounted on
udev 7,8G 4,0K 7,8G 1% /dev
tmpfs 1,6G 1,4M 1,6G 1% /run
/dev/sdb7 24G 2,2G 21G 10% /
none 4,0K 0 4,0K 0% /sys/fs/cgroup
none 5,0M 0 5,0M 0% /run/lock
none 7,8G 46M 7,8G 1% /run/shm
none 100M 32K 100M 1% /run/user
/dev/sdb5 454M 299M 128M 71% /boot
/dev/sdb6 7,3G 6,0G 898M 88% /usr
/dev/sdb2 296M 70M 227M 24% /boot/efi
/dev/sda3 3,7G 1006M 2,5G 29% /var
/dev/sda5 118G 83G 30G 74% /home
$ dpkg -l | grep linux-headers
ii linux-headers-3.13.0-106 3.13.0-106.153 all Header files related to Linux kernel version 3.13.0
ii linux-headers-3.13.0-115 3.13.0-115.162 all Header files related to Linux kernel version 3.13.0
ii linux-headers-3.13.0-123 3.13.0-123.172 all Header files related to Linux kernel version 3.13.0
ii linux-headers-3.13.0-125 3.13.0-125.174 all Header files related to Linux kernel version 3.13.0
ii linux-headers-3.13.0-128 3.13.0-128.177 all Header files related to Linux kernel version 3.13.0
ii linux-headers-3.13.0-128-generic 3.13.0-128.177 amd64 Linux kernel headers for version 3.13.0 on 64 bit x86 SMP
ii linux-headers-3.13.0-129 3.13.0-129.178 all Header files related to Linux kernel version 3.13.0
ii linux-headers-3.13.0-129-generic 3.13.0-129.178 amd64 Linux kernel headers for version 3.13.0 on 64 bit x86 SMP
ii linux-headers-3.13.0-132 3.13.0-132.181 all Header files related to Linux kernel version 3.13.0
ii linux-headers-3.13.0-132-generic 3.13.0-132.181 amd64 Linux kernel headers for version 3.13.0 on 64 bit x86 SMP
ii linux-headers-3.13.0-133 3.13.0-133.182 all Header files related to Linux kernel version 3.13.0
ii linux-headers-3.13.0-133-generic 3.13.0-133.182 amd64 Linux kernel headers for version 3.13.0 on 64 bit x86 SMP
ii linux-headers-3.13.0-135 3.13.0-135.184 all Header files related to Linux kernel version 3.13.0
ii linux-headers-3.13.0-135-generic 3.13.0-135.184 amd64 Linux kernel headers for version 3.13.0 on 64 bit x86 SMP
ii linux-headers-3.13.0-137 3.13.0-137.186 all Header files related to Linux kernel version 3.13.0
ii linux-headers-3.13.0-137-generic 3.13.0-137.186 amd64 Linux kernel headers for version 3.13.0 on 64 bit x86 SMP
ii linux-headers-3.13.0-139 3.13.0-139.188 all Header files related to Linux kernel version 3.13.0
ii linux-headers-3.13.0-139-generic 3.13.0-139.188 amd64 Linux kernel headers for version 3.13.0 on 64 bit x86 SMP
iU linux-headers-3.13.0-153-generic 3.13.0-153.203 amd64 Linux kernel headers for version 3.13.0 on 64 bit x86 SMP
ii linux-headers-3.13.0-95 3.13.0-95.142 all Header files related to Linux kernel version 3.13.0
ii linux-headers-3.13.0-96 3.13.0-96.143 all Header files related to Linux kernel version 3.13.0
ii linux-headers-3.13.0-98 3.13.0-98.145 all Header files related to Linux kernel version 3.13.0
ii linux-headers-3.13.0-98-generic 3.13.0-98.145 amd64 Linux kernel headers for version 3.13.0 on 64 bit x86 SMP
iU linux-headers-generic 3.13.0.153.163 amd64 Generic Linux kernel headers
$ ls /boot
abi-3.13.0-128-generic config-3.13.0-129-generic initrd.img-3.13.0-128-generic memtest86+.elf System.map-3.13.0-141-generic vmlinuz-3.13.0-135-generic
abi-3.13.0-129-generic config-3.13.0-132-generic initrd.img-3.13.0-129-generic memtest86+_multiboot.bin System.map-3.13.0-153-generic vmlinuz-3.13.0-135-generic.efi.signed
abi-3.13.0-132-generic config-3.13.0-133-generic initrd.img-3.13.0-132-generic retpoline-3.13.0-153-generic vmlinuz-3.13.0-128-generic vmlinuz-3.13.0-137-generic
abi-3.13.0-133-generic config-3.13.0-135-generic initrd.img-3.13.0-133-generic System.map-3.13.0-128-generic vmlinuz-3.13.0-128-generic.efi.signed vmlinuz-3.13.0-137-generic.efi.signed
abi-3.13.0-135-generic config-3.13.0-137-generic initrd.img-3.13.0-135-generic System.map-3.13.0-129-generic vmlinuz-3.13.0-129-generic vmlinuz-3.13.0-139-generic
abi-3.13.0-137-generic config-3.13.0-139-generic initrd.img-3.13.0-137-generic System.map-3.13.0-132-generic vmlinuz-3.13.0-129-generic.efi.signed vmlinuz-3.13.0-139-generic.efi.signed
abi-3.13.0-139-generic config-3.13.0-141-generic initrd.img-3.13.0-139-generic System.map-3.13.0-133-generic vmlinuz-3.13.0-132-generic vmlinuz-3.13.0-141-generic
abi-3.13.0-141-generic config-3.13.0-153-generic initrd.img-3.13.0-141-generic System.map-3.13.0-135-generic vmlinuz-3.13.0-132-generic.efi.signed vmlinuz-3.13.0-141-generic.efi.signed
abi-3.13.0-153-generic efi lost+found System.map-3.13.0-137-generic vmlinuz-3.13.0-133-generic vmlinuz-3.13.0-153-generic
config-3.13.0-128-generic grub memtest86+.bin System.map-3.13.0-139-generic vmlinuz-3.13.0-133-generic.efi.signed
$ ls /boot/ -1hs
total 290M
1,2M abi-3.13.0-128-generic
1,2M abi-3.13.0-129-generic
1,2M abi-3.13.0-132-generic
1,2M abi-3.13.0-133-generic
1,2M abi-3.13.0-135-generic
1,2M abi-3.13.0-137-generic
1,2M abi-3.13.0-139-generic
1,2M abi-3.13.0-141-generic
1,2M abi-3.13.0-153-generic
163K config-3.13.0-128-generic
163K config-3.13.0-129-generic
163K config-3.13.0-132-generic
163K config-3.13.0-133-generic
163K config-3.13.0-135-generic
163K config-3.13.0-137-generic
163K config-3.13.0-139-generic
163K config-3.13.0-141-generic
163K config-3.13.0-153-generic
4,0K efi
1,0K grub
20M initrd.img-3.13.0-128-generic
20M initrd.img-3.13.0-129-generic
20M initrd.img-3.13.0-132-generic
20M initrd.img-3.13.0-133-generic
20M initrd.img-3.13.0-135-generic
20M initrd.img-3.13.0-137-generic
20M initrd.img-3.13.0-139-generic
20M initrd.img-3.13.0-141-generic
12K lost+found
173K memtest86+.bin
174K memtest86+.elf
175K memtest86+_multiboot.bin
1,0K retpoline-3.13.0-153-generic
3,3M System.map-3.13.0-128-generic
3,3M System.map-3.13.0-129-generic
3,3M System.map-3.13.0-132-generic
3,3M System.map-3.13.0-133-generic
3,3M System.map-3.13.0-135-generic
3,3M System.map-3.13.0-137-generic
3,3M System.map-3.13.0-139-generic
3,3M System.map-3.13.0-141-generic
3,3M System.map-3.13.0-153-generic
5,6M vmlinuz-3.13.0-128-generic
5,6M vmlinuz-3.13.0-128-generic.efi.signed
5,6M vmlinuz-3.13.0-129-generic
5,6M vmlinuz-3.13.0-129-generic.efi.signed
5,6M vmlinuz-3.13.0-132-generic
5,6M vmlinuz-3.13.0-132-generic.efi.signed
5,6M vmlinuz-3.13.0-133-generic
5,6M vmlinuz-3.13.0-133-generic.efi.signed
5,6M vmlinuz-3.13.0-135-generic
5,6M vmlinuz-3.13.0-135-generic.efi.signed
5,6M vmlinuz-3.13.0-137-generic
5,6M vmlinuz-3.13.0-137-generic.efi.signed
5,6M vmlinuz-3.13.0-139-generic
5,6M vmlinuz-3.13.0-139-generic.efi.signed
5,6M vmlinuz-3.13.0-141-generic
5,6M vmlinuz-3.13.0-141-generic.efi.signed
5,7M vmlinuz-3.13.0-153-generic
$ du -s -h /usr/*
344M /usr/bin
520K /usr/games
25M /usr/include
1,9G /usr/lib
467M /usr/local
du: cannot read directory ‘/usr/lost+found’: Permission denied
16K /usr/lost+found
25M /usr/sbin
2,0G /usr/share
1,4G /usr/src
Edit
Problem seems to be related to inode capacity in /usr:
$ df -i
Filesystem Inodes IUsed IFree IUse% Mounted on
udev 2041123 604 2040519 1% /dev
tmpfs 2043915 678 2043237 1% /run
/dev/sdb7 1581056 49149 1531907 4% /
none 2043915 11 2043904 1% /sys/fs/cgroup
none 2043915 3 2043912 1% /run/lock
none 2043915 147 2043768 1% /run/shm
none 2043915 28 2043887 1% /run/user
/dev/sdb6 488640 484619 4021 100% /usr
/dev/sdb5 122400 342 122058 1% /boot
/dev/sda3 244320 33951 210369 14% /var
/dev/sda5 7839744 2857681 4982063 37% /home
/dev/sdb2 0 0 0 - /boot/efi
However, most answers for freeing up space rely on apt-get. This is not an option here because of the problems stated above, and so I need another safe way to clear some space in /usr.
Hopefully this will allow apt-get -f install to add all missing dependencies.
