I am noticing this odd behavior in Ubuntu 16.04 desktop. I have open-ssh installed and working. But in one odd scenario, I noticed a few things break down.
Here is a breakdown:
  • When I am already logged in, I am able to remotely SSH
  • When I am logged out, say after a reboot, I am able to get to the SSH prompt, enter my password, but as the password is going through, the network drops
  • After that happens, I need to manually open up my laptop, log in manually, then restart my network-manager (I am using WiFi - but my network is solid)
  • If I log in manually to begin with, this is a non issue.
So basically, if I am remote and need to reboot my machine, I am in a situation where the machine will not be accessible until I get back to it locally.
I am not sure which log files can give hints as to what is happening, but let me know if you have ideas
Logs:
$ ssh -vvv eric@myserver.com -p 22
OpenSSH_6.6.1, OpenSSL 1.0.1f 6 Jan 2014
debug1: Reading configuration data /home/ubuntu/.ssh/config
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: Applying options for *
debug2: ssh_connect: needpriv 0
debug1: Connecting to myserver.com [123.123.123.123] port 22.
debug1: Connection established.
debug3: Incorrect RSA1 identifier
debug3: Could not load "/home/ubuntu/.ssh/id_rsa" as a RSA1 public key
debug1: identity file /home/ubuntu/.ssh/id_rsa type 1
debug1: identity file /home/ubuntu/.ssh/id_rsa-cert type -1
debug1: identity file /home/ubuntu/.ssh/id_dsa type -1
debug1: identity file /home/ubuntu/.ssh/id_dsa-cert type -1
debug1: identity file /home/ubuntu/.ssh/id_ecdsa type -1
debug1: identity file /home/ubuntu/.ssh/id_ecdsa-cert type -1
debug1: identity file /home/ubuntu/.ssh/id_ed25519 type -1
debug1: identity file /home/ubuntu/.ssh/id_ed25519-cert type -1
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_6.6.1p1 Ubuntu-2ubuntu2.4
debug1: Remote protocol version 2.0, remote software version OpenSSH_7.2p2 Ubuntu-4ubuntu2.4
debug1: match: OpenSSH_7.2p2 Ubuntu-4ubuntu2.4 pat OpenSSH* compat 0x04000000
debug2: fd 3 setting O_NONBLOCK
debug3: put_host_port: [myserver.com]:22
debug3: load_hostkeys: loading entries for host "[myserver.com]:22" from file "/home/ubuntu/.ssh/known_hosts"
debug3: load_hostkeys: found key type ECDSA in file /home/ubuntu/.ssh/known_hosts:5
debug3: load_hostkeys: loaded 1 keys
debug3: order_hostkeyalgs: prefer hostkeyalgs: ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug2: kex_parse_kexinit: curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1
debug2: kex_parse_kexinit: ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,ssh-ed25519-cert-v01@openssh.com,ssh-rsa-cert-v01@openssh.com,ssh-dss-cert-v01@openssh.com,ssh-rsa-cert-v00@openssh.com,ssh-dss-cert-v00@openssh.com,ssh-ed25519,ssh-rsa,ssh-dss
debug2: kex_parse_kexinit: aes128-ctr,aes192-ctr,aes256-ctr,arcfour256,arcfour128,aes128-gcm@openssh.com,aes256-gcm@openssh.com,chacha20-poly1305@openssh.com,aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,aes192-cbc,aes256-cbc,arcfour,rijndael-cbc@lysator.liu.se
debug2: kex_parse_kexinit: hmac-md5-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-ripemd160-etm@openssh.com,hmac-sha1-96-etm@openssh.com,hmac-md5-96-etm@openssh.com,hmac-md5,hmac-sha1,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-ripemd160,hmac-ripemd160@openssh.com,hmac-sha1-96,hmac-md5-96
debug2: kex_parse_kexinit: none,zlib@openssh.com,zlib
debug2: kex_parse_kexinit: first_kex_follows 0
debug2: kex_parse_kexinit: reserved 0
debug2: kex_parse_kexinit: curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group14-sha1
debug2: kex_parse_kexinit: ssh-rsa,rsa-sha2-512,rsa-sha2-256,ecdsa-sha2-nistp256,ssh-ed25519
debug2: kex_parse_kexinit: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com
debug2: kex_parse_kexinit: umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1
debug2: mac_setup: setup hmac-sha1-etm@openssh.com
debug1: kex: server->client aes128-ctr hmac-sha1-etm@openssh.com none
debug1: kex: client->server aes128-ctr hmac-sha1-etm@openssh.com none
debug1: sending SSH2_MSG_KEX_ECDH_INIT
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug1: Server host key: ECDSA d4:10:ea:83:7c:7f:3f:a8:42:1c:f6:73:c6:f8:06:59
debug3: put_host_port: [123.123.123.123]:22
debug3: load_hostkeys: loading entries for host "[123.123.123.123]:22" from file "/home/ubuntu/.ssh/known_hosts"
debug3: load_hostkeys: found key type ECDSA in file /home/ubuntu/.ssh/known_hosts:4
debug1: Host '[myserver.com]:22' is known and matches the ECDSA host key.
debug1: Found key in /home/ubuntu/.ssh/known_hosts:5
Warning: the ECDSA host key for '[myserver.com]:22' differs from the key for the IP address '[123.123.123.123]:22'
Offending key for IP in /home/ubuntu/.ssh/known_hosts:4
Matching host key in /home/ubuntu/.ssh/known_hosts:5
Are you sure you want to continue connecting (yes/no)? yes
debug1: ssh_ecdsa_verify: signature correct
debug2: kex_derive_keys
debug2: set_newkeys: mode 1
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug2: set_newkeys: mode 0
debug1: SSH2_MSG_NEWKEYS received
debug1: SSH2_MSG_SERVICE_REQUEST sent
debug2: service_accept: ssh-userauth
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug2: key: /home/ubuntu/.ssh/id_rsa (0x56131c51de90),
debug2: key: /home/ubuntu/.ssh/id_dsa ((nil)),
debug2: key: /home/ubuntu/.ssh/id_ecdsa ((nil)),
debug2: key: /home/ubuntu/.ssh/id_ed25519 ((nil)),
debug1: Authentications that can continue: publickey,password
debug3: start over, passed a different list publickey,password
debug3: preferred gssapi-keyex,gssapi-with-mic,publickey,keyboard-interactive,password
debug3: authmethod_lookup publickey
debug3: remaining preferred: keyboard-interactive,password
debug3: authmethod_is_enabled publickey
debug1: Next authentication method: publickey
debug1: Offering RSA public key: /home/ubuntu/.ssh/id_rsa
debug3: send_pubkey_test
debug2: we sent a publickey packet, wait for reply
debug1: Trying private key: /home/ubuntu/.ssh/id_dsa
debug3: no such identity: /home/ubuntu/.ssh/id_dsa: No such file or directory
debug1: Trying private key: /home/ubuntu/.ssh/id_ecdsa
debug3: no such identity: /home/ubuntu/.ssh/id_ecdsa: No such file or directory
debug1: Trying private key: /home/ubuntu/.ssh/id_ed25519
debug3: no such identity: /home/ubuntu/.ssh/id_ed25519: No such file or directory
debug2: we did not send a packet, disable method
debug3: authmethod_lookup password
debug3: remaining preferred: ,password
debug3: authmethod_is_enabled password
debug1: Next authentication method: password
eric@myserver.com's password:
debug3: packet_send2: adding 64 (len 59 padlen 5 extra_pad 64)
debug2: we sent a password packet, wait for reply
debug1: Authentication succeeded (password).
Authenticated to myserver.com ([123.123.123.123]:22).
debug1: channel 0: new [client-session]
debug3: ssh_session2_open: channel_new: 0
debug2: channel 0: send open
debug1: Requesting no-more-sessions@openssh.com
debug1: Entering interactive session.
E.S.
  • 133
