I'm having some issues with the last release of Lubuntu on my old pc (ACER TravelMate 2702WLMi).
The main problem is that I cannot connect to any wifi line. In the network panel in the application bar I can only see Ethernet Network, while there's no Wifi connections.
I've searched through some forums and the only post that seemed to correspond to my problem is this one.
The problem is that probably I don't have a Broadcom card but a Realtek one, but I'm not sure about it. The only thing about I'm sure is that the guide would be the solution for my problem if I only had a Broadcom card because I've the exactly same problems.
What can I do to discover my wireless drivers and how to install them correctly on Lubuntu to make wifi work?
I'm a user with no advanced knowledge in Linux, so I would need clear explanations on how to make, compile, etc.
Result of
$ lspci -knn | grep net -A2
00:14.4 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD/ATI] IXP200 3COM 3C920B Ethernet Controller [1002:4342]
00:14.5 Multimedia audio controller [0401]: Advanced Micro Devices, Inc. [AMD/ATI] IXP150 AC'97 Audio Controller [1002:4341] (rev 01)
Subsystem: Acer Incorporated [ALI] IXP150 AC'97 Audio Controller [1025:0065]
02:02.0 Ethernet controller [0200]: InProComm Inc. IPN 2220 802.11g [17fe:2220]
Subsystem: AMBIT Microsystem Corp. T60N871 802.11g Mini PCI Wireless Adapter [1468:0305]
02:03.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL-8100/8101L/8139 PCI Fast Ethernet Adapter [10ec:8139] (rev 10)
Subsystem: Acer Incorporated [ALI] RTL-8100/8101L/8139 PCI Fast Ethernet Adapter [1025:0036]
Kernel driver in use: 8139too
Kernel modules: 8139cp, 8139too
Result of
lspci -knn | grep Ethernet -A2
Result of
lspci; lsusb
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD/ATI] RS300 Host Bridge (rev 02)
00:01.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] RS300 AGP Bridge
00:13.0 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] OHCI USB Controller #1 (rev 01)
00:13.1 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] OHCI USB Controller #2 (rev 01)
00:13.2 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] EHCI USB Controller (rev 01)
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD/ATI] SMBus (rev 1a)
00:14.1 IDE interface: Advanced Micro Devices, Inc. [AMD/ATI] Dual Channel Bus Master PCI IDE Controller
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD/ATI] Device 434c
00:14.4 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] IXP200 3COM 3C920B Ethernet Controller
00:14.5 Multimedia audio controller: Advanced Micro Devices, Inc. [AMD/ATI] IXP150 AC'97 Audio Controller (rev 01)
00:14.6 Modem: Advanced Micro Devices, Inc. [AMD/ATI] IXP AC'97 Modem (rev 01)
01:05.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] RS300M [Mobility Radeon 9100 IGP]
02:02.0 Ethernet controller: InProComm Inc. IPN 2220 802.11g
02:03.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8100/8101L/8139 PCI Fast Ethernet Adapter (rev 10)
02:04.0 CardBus bridge: ENE Technology Inc CB1410 Cardbus Controller (rev 01)
Bus 001 Device 010: ID 0bb4:0004 HTC (High Tech Computer Corp.)
Bus 003 Device 002: ID 0f62:1001 Acrox Technologies Co., Ltd Targus Mini Trackball Optical Mouse
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
