I have a laptop (Schenker S403) and installed Kubuntu 18.04. Previously I had 17.10 with no problems. I disabled the graphics card in the NVidia-x-server-settings.
Now my laptop runs hot and the fan spins nonstop although I also disabled it in the new installation (no upgrade but a totally new installation). Investigating I found and did some stuff:
  • My CPU governor is on powersafe on AC and DC.
  • I have tlp up and running.
  • prime-select query: intel
  • Nvidia X Server Settings shows Intel as the choice (power saving mode).
...but:
 nopinger@my-laptop ~ lspci
+00:00.0 Host bridge: Intel Corporation Haswell-ULT DRAM Controller (rev 09)
00:02.0 VGA compatible controller: Intel Corporation Haswell-ULT Integrated Graphics Controller (rev 09)
00:03.0 Audio device: Intel Corporation Haswell-ULT HD Audio Controller (rev 09)
00:14.0 USB controller: Intel Corporation 8 Series USB xHCI HC (rev 04)
00:16.0 Communication controller: Intel Corporation 8 Series HECI #0 (rev 04)
00:1b.0 Audio device: Intel Corporation 8 Series HD Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 1 (rev e4)
00:1c.2 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 3 (rev e4)
00:1c.3 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 4 (rev e4)
00:1c.4 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 5 (rev e4)
00:1d.0 USB controller: Intel Corporation 8 Series USB EHCI #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation 8 Series LPC Controller (rev 04)
00:1f.2 SATA controller: Intel Corporation 8 Series SATA Controller 1 [AHCI mode] (rev 04)
00:1f.3 SMBus: Intel Corporation 8 Series SMBus Controller (rev 04)
02:00.0 Network controller: Intel Corporation Wireless 7260 (rev 73)
03:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTL8411B PCI Express Card Reader (rev 01)
03:00.1 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 12)
04:00.0 3D controller: NVIDIA Corporation GK107M [GeForce GT 745M] (rev a1)
So there seems to be a problem, because the 3D controller is still NVIDIA stuff And really, PowerTOP shows a 100% usage of the graphics card:
100,0%        PCI-Gerät: NVIDIA Corporation GK107M [GeForce GT 745M]
How can I totally disable this stuff? It drains my battery and the fan is too noisy because of it.
The only useful answer I found is: How can I uninstall a nvidia driver completely ?
And it is quite old, nvidia-common doesn't exist anymore.
Update 1:
I did the following things:
nopinger@my-laptop ~ cat /etc/modprobe.d/blacklist.conf | grep nouveau
blacklist nouveau
blacklist lbm-nouveau
alias nouveau off
alias lbm-nouveau off
then updated (sudo update-initramfs -u)
  • updated grub to:
nopinger@my-laptop ~ cat /etc/default/grub | grep nouveau
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash nouveau.runpm=0 nouveau.modeset=0"
then updated grub with sudo update-grub .
  • rebooted
Result:
  • Powertop show no change, the card has a 100% usage.
  • 3D Controller is also unchanged.
I don't understand how it is still working in a way.
karel
  • 122,292
  • 133
  • 301
  • 332
I've been battling the same issue for quite some time now and no answer in sight.
I did however install tlp and powertop and I've noticed a funny thing:
When you run sudo powertop --auto-tune and then sudo powertop for me it shows nvidia card to 0%.
  • Later Edit *
It is all related to tunables in powertop more specifically "Sata link power management" which TLP does not activate by default. When that is set the card seems to power off.
PCatinean
  • 23
