I just got a brand new ASUS UX580GD, and have installed Ubuntu 18.04. My issue which I noticed straight away is the screenpad. It just plain doesn't work as a touchpad, probably since it isn't recognized as one. I haven't found anyone having this issue, probably since no one actually installed ubuntu on one of these. Does anyone know if there's a driver or a fix so the trackpad can at least be used (bonus points for the screen as well).
Thanks!
I had the same problem with my ASUS (UX580GD)
I fixed it by installing Ubuntu 18.10.
First, i tried it without installing Touch-pad worked fine.
Then, when i installed it, and after the first reboot the system freezes after login. (nothing at all responds)
I chose to boot on rescue mode and executed this command:
$ sudo ubuntu-drivers autoinstall
Once the installation is concluded, i rebooted the system and my problem is solved.
Xalbi
  • 64
Try to combine Touchscreen with external display (How to force Ubuntu to detect external display?)
iegik
  • 1,893
ScreenPad lights up in Xubuntu 19.10. Last Kubuntu shows logo in screenpad while boots, but there's no software for Linux systems
