I am trying to install cuda 9.0 instead of cuda 9.2 as the tensorflow is not compatible with it. I tried the following:
aims@aims:~/Downloads$ sudo dpkg -i "cuda-repo-ubuntu1604_9.0.176-1_amd64(1).deb"
(Reading database ... 212533 files and directories currently installed.)
Preparing to unpack cuda-repo-ubuntu1604_9.0.176-1_amd64(1).deb ...
Unpacking cuda-repo-ubuntu1604 (9.0.176-1) over (9.0.176-1) ...
Setting up cuda-repo-ubuntu1604 (9.0.176-1) ...
aims@aims:~/Downloads$ sudo apt-get update
Ign:1 http://dl.google.com/linux/chrome/deb stable InRelease
Ign:2 http://developer.download.nvidia.com/compute/cuda/repos/ubuntu1604/x86_64  InRelease
Hit:3 http://ppa.launchpad.net/graphics-drivers/ppa/ubuntu xenial InRelease
Hit:4 http://security.ubuntu.com/ubuntu xenial-security InRelease
Hit:5 http://archive.ubuntu.com/ubuntu xenial InRelease
Hit:6 http://developer.download.nvidia.com/compute/cuda/repos/ubuntu1604/x86_64  Release
Hit:8 http://dl.google.com/linux/chrome/deb stable Release
Hit:9 http://archive.ubuntu.com/ubuntu xenial-updates InRelease
Hit:11 http://archive.canonical.com xenial InRelease
Hit:12 http://ppa.launchpad.net/nemh/systemback/ubuntu xenial InRelease
Reading package lists... Done
aims@aims:~/Downloads$ sudo apt-get install cuda
Building dependency tree
The following additional packages will be installed:
  cuda-9-2 cuda-command-line-tools-9-2 cuda-compiler-9-2 cuda-cublas-9-2 cuda-cublas-dev-9-2 cuda-cudart-9-2 cuda-cudart-dev-9-2 cuda-cufft-9-2 cuda-cufft-dev-9-2 cuda-cuobjdump-9-2 cuda-cupti-9-2 cuda-curand-9-2 cuda-curand-dev-9-2 cuda-cusolver-9-2 cuda-cusolver-dev-9-2
  cuda-cusparse-9-2 cuda-cusparse-dev-9-2 cuda-demo-suite-9-2 cuda-documentation-9-2 cuda-driver-dev-9-2 cuda-drivers cuda-gdb-9-2 cuda-gpu-library-advisor-9-2 cuda-libraries-9-2 cuda-libraries-dev-9-2 cuda-license-9-2 cuda-memcheck-9-2 cuda-misc-headers-9-2 cuda-npp-9-2
  cuda-npp-dev-9-2 cuda-nsight-9-2 cuda-nvcc-9-2 cuda-nvdisasm-9-2 cuda-nvgraph-9-2 cuda-nvgraph-dev-9-2 cuda-nvml-dev-9-2 cuda-nvprof-9-2 cuda-nvprune-9-2 cuda-nvrtc-9-2 cuda-nvrtc-dev-9-2 cuda-nvtx-9-2 cuda-nvvp-9-2 cuda-runtime-9-2 cuda-samples-9-2 cuda-toolkit-9-2
  cuda-tools-9-2 cuda-visual-tools-9-2
The following NEW packages will be installed:
  cuda cuda-9-2 cuda-command-line-tools-9-2 cuda-compiler-9-2 cuda-cublas-9-2 cuda-cublas-dev-9-2 cuda-cudart-9-2 cuda-cudart-dev-9-2 cuda-cufft-9-2 cuda-cufft-dev-9-2 cuda-cuobjdump-9-2 cuda-cupti-9-2 cuda-curand-9-2 cuda-curand-dev-9-2 cuda-cusolver-9-2
  cuda-cusolver-dev-9-2 cuda-cusparse-9-2 cuda-cusparse-dev-9-2 cuda-demo-suite-9-2 cuda-documentation-9-2 cuda-driver-dev-9-2 cuda-drivers cuda-gdb-9-2 cuda-gpu-library-advisor-9-2 cuda-libraries-9-2 cuda-libraries-dev-9-2 cuda-license-9-2 cuda-memcheck-9-2
  cuda-misc-headers-9-2 cuda-npp-9-2 cuda-npp-dev-9-2 cuda-nsight-9-2 cuda-nvcc-9-2 cuda-nvdisasm-9-2 cuda-nvgraph-9-2 cuda-nvgraph-dev-9-2 cuda-nvml-dev-9-2 cuda-nvprof-9-2 cuda-nvprune-9-2 cuda-nvrtc-9-2 cuda-nvrtc-dev-9-2 cuda-nvtx-9-2 cuda-nvvp-9-2 cuda-runtime-9-2
  cuda-samples-9-2 cuda-toolkit-9-2 cuda-tools-9-2 cuda-visual-tools-9-2
0 upgraded, 48 newly installed, 0 to remove and 4 not upgraded.
Need to get 0 B/1,145 MB of archives.
After this operation, 2,642 MB of additional disk space will be used.
Do you want to continue? [Y/n]
As you can see that the Cuda 9.2 is getting reflected everywhere, even though I haven't added it. Previously I added but before going for 9.0 I have purged the cuda 9.2. But getting issues in installation. Kindly, help me.
The repo http://developer.download.nvidia.com/compute/cuda/repos/ubuntu1604/x86_64/ contains 9.0, 9.1 and 9.2.
When you run sudo apt install cuda it will automatically pick the newest version. Instead, you should specify the version during the installation:
sudo apt install cuda-9-0
then put a hold on it after it is installed so that it doesn't try to upgrade it to the newest version in that repository when you run sudo apt upgrade in the future:
sudo apt hold cuda-9-0
I have thrown together an answer for installing all 3 versions of CUDA in 16.04 at https://askubuntu.com/a/1025949/231142
Terrance
  • 43,712
When you installed cuda-repo-ubuntu1604_9.0.176-1_amd64(1).deb file then it added it's repository into /etc/apt/sources.list.d directory. Go to sources.list.d directory and delete them.
sudo rm /etc/apt/sources.list.d/cuda*
sudo apt update
Now it will not update to v9.2
