Did a fresh install of 18.04 alongside Windows 10 (UEFI). Now my system boots only into grub2 commandline.
I am able to boot into both windows by executing
chainloader **(hd0,gpt1)**/efi/Microsoft/bootmfgw.efi
and ubuntu by executing
set prefix=(hd0,gpt6)/boot/grub
set root=**(hd0,gpt6)**
insmod linux
insmod normal
normal
I ran grub-install, boot repair several times after booting into ubuntu, but to no effect. I still keep booting into grub commandline.
Any help is appreciated. Boot repair pastebin - http://paste.ubuntu.com/p/64X9XmshBJ
Screenshot of gparted:
I have tried these, and it did not work:
  • grub-install with grub-efi-amd4
  • grub install from live usb
  • boot-repair from live usb or ubuntu
  • fresh install of 18.04 again lands in grub manual
When using windows 10 on sda3 and you install and boot ubuntu 18.04
sudo blkid
 (read uuid from /dev/sda3, used below as uuid_read_above)
sudo nano /etc/default/grub
 (add line to the end of the file:)
    GRUB_PRELOAD_MODULES="part_msdos"
sudo update-grub
sudo nano /etc/grub.d/40_custom
 (add these lines to the end of the file:)
    menuentry "Windows 10" {
     insmod ntfs
     set root='(hd0,3)'
     search --no-floppy --fs-uuid --set uuid_read_above
     ntldr /bootmgr
     chainloader +1
sudo update-grub
sudo grub-install /dev/sda
sudo update-grub
exit and boot from hdd, should see menu with "Windows 10"
