Can anyone help solve the runtime error for Netgen 5.3.1. NETGEN is an automatic 3d tetrahedral mesh generator. The error message is:
:/opt/netgen/bin$ ./netgen
NETGEN-5.3.1
Developed by Joachim Schoeberl at
2010-xxxx Vienna University of Technology
2006-2010 RWTH Aachen University
1996-2006 Johannes Kepler University Linz
optfile ./ng.opt does not exist - using default values
X Error of failed request:  BadValue (integer parameter out of range for operation)
  Major opcode of failed request:  154 (GLX)
  Minor opcode of failed request:  3 (X_GLXCreateContext)
  Value in failed request:  0x0
  Serial number of failed request:  558
  Current serial number in output stream:  559
Instructions on installing netgen-5.3.1 are given here.
The software seems to have followed ./configure , make and sudo make install correctly.
I followed the instructions from a web page with a similar error message, but it did not resolve the problem. I.e. installing Togl-1.7 .
The end output of sudo make install gave:
libtool: relink: g++  -fPIC -DPIC -shared -nostdlib /usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/crti.o /usr/lib/gcc/x86_64-linux-gnu/5/crtbeginS.o  .libs/nglib.o   -Wl,-rpath -Wl,/opt/netgen/lib -L/opt/netgen/lib -linterface -lgeom2d -lcsg -lstl -locc -lmesh -L/usr/lib/gcc/x86_64-linux-gnu/5 -L/usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/5/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/5/../../.. -lstdc++ -lm -lgomp -lpthread -lc -lgcc_s /usr/lib/gcc/x86_64-linux-gnu/5/crtendS.o /usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/crtn.o  -O2 -fopenmp   -fopenmp -Wl,-soname -Wl,libnglib.so -o .libs/libnglib.so
libtool: install: /usr/bin/install -c .libs/libnglib.soT /opt/netgen/lib/libnglib.so
libtool: install: /usr/bin/install -c .libs/libnglib.lai /opt/netgen/lib/libnglib.la
libtool: finish: PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin:/sbin" ldconfig -n /opt/netgen/lib
Libraries have been installed in:
   /opt/netgen/lib
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the `-LLIBDIR'
flag during linking and do at least one of the following:
   - add LIBDIR to the `LD_LIBRARY_PATH' environment variable
     during execution
   - add LIBDIR to the `LD_RUN_PATH' environment variable
     during linking
   - use the `-Wl,-rpath -Wl,LIBDIR' linker flag
   - have your system administrator add LIBDIR to `/etc/ld.so.conf'
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
test -z "/opt/netgen/bin" || /bin/mkdir -p "/opt/netgen/bin"
  /bin/bash ../libtool   --mode=install /usr/bin/install -c ng_vol ng_stl '/opt/netgen/bin'
libtool: install: /usr/bin/install -c .libs/ng_vol /opt/netgen/bin/ng_vol
libtool: install: /usr/bin/install -c .libs/ng_stl /opt/netgen/bin/ng_stl
test -z "/opt/netgen/share/netgen" || /bin/mkdir -p "/opt/netgen/share/netgen"
 /usr/bin/install -c -m 644 cube.surf '/opt/netgen/share/netgen'
test -z "/opt/netgen/include" || /bin/mkdir -p "/opt/netgen/include"
 /usr/bin/install -c -m 644 nglib.h '/opt/netgen/include'
make[2]: Leaving directory '/home/brendan/Documents/hpfem-mpt/netgen-5.3.1/nglib'
make[1]: Leaving directory '/home/brendan/Documents/hpfem-mpt/netgen-5.3.1/nglib'
make[1]: Entering directory '/home/brendan/Documents/hpfem-mpt/netgen-5.3.1'
make[2]: Entering directory '/home/brendan/Documents/hpfem-mpt/netgen-5.3.1'
make[2]: Nothing to be done for 'install-exec-am'.
make[2]: Nothing to be done for 'install-data-am'.
make[2]: Leaving directory '/home/brendan/Documents/hpfem-mpt/netgen-5.3.1'
make[1]: Leaving directory '/home/brendan/Documents/hpfem-mpt/netgen-5.3.1'
ponsfrilus
  • 596
  • 17
It seems to be a known bug 1556445.
If you use version 4.9.13 from official repository (installed with sudo apt-get install netgen) you can "patch" it by running the following command manually:
sudo sed -i "s/\-indirect\ true\ \}/\-indirect\ false\ \}/g" \
/usr/share/netgen/drawing.tcl
This method came from Netgen SourceForge Maillist:
Joachim Schoeberl - 2016-02-04
edit file ng/drawing.tcl line 14:
if {[catch {togl .ndraw -width 400 -height 300 -rgba true -double true -depth true -privatecmap false -stereo false -indirect true }] } { ....
change "-indirect true" to "-indirect false"
Joachim
May work with manually compiled version too (need changes in filepath - /opt/netgen/bin/drawing.tcl).
N0rbert
  • 103,263
I found I needed to follow my previous method, editing file /opt/netgen/bin/drawing.tcl at line 14
changing -indirect true to -indirect false
& executing at /opt/netgen/bin using ./netgen was successful!
I found that executing it with netgen &! produced the same error message.
The error was that at /opt/netgen/bin/drawing.tcl:
# use this one for Togl 2.0
# if {[catch {togl .ndraw -width 400 -height 300  -rgba true -double true -depth true -privatecmap false -stereo false -indirect false -create init  -display draw -reshape reshape  }] } {
if {[catch {togl .ndraw -width 400 -height 300  -rgba true -double true -depth true -privatecmap false -stereo false -indirect true }] } {    puts "no OpenGL"
I had altered the commented code at line 12 instead of line 14, as both lines look similar.
