Today I try to install openjdk 7 on my ubuntu 18.04 system. It always install oracle-java8-installer instead openjdk 7. Please help me
apt-get install openjdk-7-jre
Here you got a very good answer with a step-by-step instruction:
Download it here from Oracle.
I have installed OpenJDK 1.7 on Ubuntu 18.04
Step 1. Install OpenJDK 1.7
sudo dpkg -i https://packages.debian.org/sid/libjpeg62-turbo
sudo dpkg -i https://packages.debian.org/experimental/openjdk-7-jre-headless
sudo dpkg -i https://packages.debian.org/experimental/openjdk-7-jdk
Step 2. Switch to OpenJDK 1.7
export PATH=/usr/lib/jvm/java-7-openjdk-amd64/bin:$PATH
Note: If you want to use javac command instead of openjdk 1.7, use below command
sudo update-alternatives --config java
