How do I install gparted on Ubuntu 18.04? Every method proves to return the same unsuccessful result.
1) Through the terminal.
sudo apt install gparted
Result:
Reading package lists... Done
Building dependency tree
The following additional packages will be installed:
  libatkmm-1.6-1v5 libcairomm-1.0-1v5 libglibmm-2.4-1v5 libgtkmm-2.4-1v5
  libpangomm-1.4-1v5 libsigc++-2.0-0v5
Suggested packages:
  xfsprogs reiserfsprogs reiser4progs jfsutils kpartx dmraid gpart
The following NEW packages will be installed:
  gparted libatkmm-1.6-1v5 libcairomm-1.0-1v5 libglibmm-2.4-1v5
  libgtkmm-2.4-1v5 libpangomm-1.4-1v5 libsigc++-2.0-0v5
0 upgraded, 7 newly installed, 0 to remove and 126 not upgraded.
Need to get 1,798 kB of archives.
After this operation, 10.0 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Err:1 http://in.archive.ubuntu.com/ubuntu bionic/main amd64 libsigc++-2.0-0v5 amd64 2.10.0-2
  502  Connection timed out [IP: 2001:67c:1560:8001::14 80]
Err:2 http://in.archive.ubuntu.com/ubuntu bionic/main amd64 libglibmm-2.4-1v5 amd64 2.56.0-1
Err:3 http://in.archive.ubuntu.com/ubuntu bionic/main amd64 libatkmm-1.6-1v5 amd64 2.24.2-3
Err:4 http://in.archive.ubuntu.com/ubuntu bionic/main amd64 libcairomm-1.0-1v5 amd64 1.12.2-3
Err:5 http://in.archive.ubuntu.com/ubuntu bionic/main amd64 libpangomm-1.4-1v5 amd64 2.40.1-4
Err:6 http://in.archive.ubuntu.com/ubuntu bionic/main amd64 libgtkmm-2.4-1v5 amd64 1:2.24.5-2
Err:7 http://in.archive.ubuntu.com/ubuntu bionic/main amd64 gparted amd64 0.30.0-3ubuntu1
E: Failed to fetch http://in.archive.ubuntu.com/ubuntu/pool/main/libs/libsigc++-2.0/libsigc++-2.0-0v5_2.10.0-2_amd64.deb  502  Connection timed out [IP: 2001:67c:1560:8001::14 80]
E: Failed to fetch http://in.archive.ubuntu.com/ubuntu/pool/main/g/glibmm2.4/libglibmm-2.4-1v5_2.56.0-1_amd64.deb  502  Connection timed out [IP: 2001:67c:1560:8001::14 80]
E: Failed to fetch http://in.archive.ubuntu.com/ubuntu/pool/main/a/atkmm1.6/libatkmm-1.6-1v5_2.24.2-3_amd64.deb  502  Connection timed out [IP: 2001:67c:1560:8001::14 80]
E: Failed to fetch http://in.archive.ubuntu.com/ubuntu/pool/main/c/cairomm/libcairomm-1.0-1v5_1.12.2-3_amd64.deb  502  Connection timed out [IP: 2001:67c:1560:8001::14 80]
E: Failed to fetch http://in.archive.ubuntu.com/ubuntu/pool/main/p/pangomm/libpangomm-1.4-1v5_2.40.1-4_amd64.deb  502  Connection timed out [IP: 2001:67c:1560:8001::14 80]
E: Failed to fetch http://in.archive.ubuntu.com/ubuntu/pool/main/g/gtkmm2.4/libgtkmm-2.4-1v5_2.24.5-2_amd64.deb  502  Connection timed out [IP: 2001:67c:1560:8001::14 80]
E: Failed to fetch http://in.archive.ubuntu.com/ubuntu/pool/main/g/gparted/gparted_0.30.0-3ubuntu1_amd64.deb  502  Connection timed out [IP: 2001:67c:1560:8001::14 80]
2) Through Ubuntu Software Center
3) Downloading the .deb.
Any idea on how do I rectify this and go ahead with the installation?
abu_bua
  • 11,313
Open your terminal and write the following commands
  1. sudo apt-get update - to update the repositories and package
  2. sudo apt-get install gparted - install gparted
  3. sudo dpkg -l gparted - check and confirm installation
  4. sudo gparted - to open gparted
and you are done :-)
vaibnak
  • 191
  1. Download Gparted as an ISO file
  2. Burn it in a USB flash
  3. Plug the USB flash into your Computer
  4. Start your computer with the bootable USB that you already made
  5. Use the Gparted app like live
And good luck
Zanna
  • 72,312
Smail
