You could easily configure Windows 10 to AHCI using the following procedure:
- First, configure BIOS to RAID, so you'll be able to boot into Windows 10.
- In Windows, run command prompt as admin.
- In the command prompt, run:
bcdedit /set {current} safeboot minimal. This will let you boot into safe mode regardless of SATA setting.
- Reboot, and re-enter the BIOS Setup.
In the BIOS, change the SATA operation mode back from RAID to AHCI. Save and reboot.
- Log on to Windows again.
- Open command prompt as admin, and run:
bcdedit /deletevalue {current} safeboot.
- Reboot once more - Windows should now start in AHCI mode with no issues.
I've used this procedure with several laptops - worked like a charm every time.
In my case, Dell laptop was default configured to RAID, and I had to change it to AHCI for Ubuntu 16.04 live USB to work, since it's not shipped with RAID drivers (and RAID setting doesn't make much sense anyway with one SSD disk setup, but that's another story).
Note that, if accidentaly the BIOS switches back to the RAID default on some occasion (for example, after a BIOS update - unlikely, but happens), and you hit a blue screen when booting into Windows - just switch the BIOS SATA setting back to AHCI, and you're good.
