I am getting error when I run sudo apt-get upgrade
output error :
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] Y
Setting up redis-server (5:4.0.9-1) ...
dpkg-statoverride: error: user 'redis' does not exist
dpkg: error processing package redis-server (--configure):
 installed redis-server package post-installation script subprocess returned error exit status 2
 redis-server
the error about redis-server and can not remove redis-server.
my linux is ubuntu 18 Desktop.
You should probably alter the redis.conf file to force it to use IPv4 if it supports that mode only and then maybe you could run it without IPv6.
nano /etc/redis/redis.conf
Simply remove the ::1 IPv6 loopback address from the bind config option:
- bind 127.0.0.1 ::1
+ bind 127.0.0.1
Now redis will not try to use the IPv6 network.
Try to install again
apt install redis-server
Test the Redis Instance Functionality To test that your service is functioning correctly, connect to the Redis server with the command-line client:
redis-cli
In the prompt that follows, test connectivity by typing:
ping You should see:
$ 127.0.0.1:6379> ping
Output
PONG
Check that you can set keys by typing:
$ 127.0.0.1:6379> set test "It's working!"
Output
OK
Now, retrieve the value by typing:
$ 127.0.0.1:6379> get test
You should be able to retrieve the value we stored:
Output
$ 127.0.0.1:6379> "It's working!"
Exit the Redis prompt to get back to the shell:
127.0.0.1:6379> exit
As a final test, let's restart the Redis instance:
$ sudo systemctl restart redis
For me i encountered this error while trying to run a script for installing binwalk
if lsb_release -r | grep -q 14.04; then
sudo apt remove binwalk
sudo apt install python-lzma squashfs-tools
git clone https://github.com/ReFirmLabs/binwalk.git
cd binwalk
sudo python setup.py install --prefix=/usr/local
cd ..
rm -rf binwalk
else
sudo apt install binwalk
fi
I just stopped redis using sudo snap stop redis and ran the script again, it worked perfectly.
