Since I did not receive any answer to this question and I have to manually restart gnome-shell each time the PC comes back from suspend to correct the distorted colors, I would like to know how to automatically restart Gnome Shell after suspend instead of doing Alt + F2 - r.
Installed Gnome extensions: Dash to Panel and Arc Menu. This is not a duplicate of a previous question. This specifically about automatically restarting Gnome Shell after coming out from suspend. Questions are totally different.
Edit: following the suggestions on comments:
a. Created a file on /etc/systemd/system called restart-gnome-shell.service and add the following:
[Unit]
Description=Restart Gnome-Shell
Before=sleep.target
StopWhenUnneeded=yes
[Service]
Type=oneshot
RemainAfterExit=yes
ExecStop=-/path/to/script.sh
[Install]
WantedBy=sleep.target
The script.sh contents are:
#! /bin/bash
gnome-shell --replace
The script has execution permissions and I enabled and started the service which was recognized by systemctl. This did not work.
This is the status after waking up from suspend:
● restart-gnome-shell.service - Restart Gnome-Shell
   Loaded: loaded (/etc/systemd/system/restart-gnome-shell.service; disabled; vendor preset: enabled)
   Active: inactive (dead)
jul 08 12:51:07 Enrique-PC systemd[1]: Started Restart Gnome-Shell.
jul 08 15:53:08 Enrique-PC systemd[1]: restart-gnome-shell.service: Unit not needed anymore. Stopping.
jul 08 15:53:08 Enrique-PC systemd[1]: Stopping Restart Gnome-Shell...
jul 08 15:53:08 Enrique-PC restart-gnome-shell.sh[2119]: Window manager warning: Unsupported session type
jul 08 15:53:08 Enrique-PC systemd[1]: Stopped Restart Gnome-Shell.
b. Created an executable script on /lib/systemd/system-sleep with the following contents:
case "${1}" in
    post)
esac
It did not work.
eera5607
  • 367
Change your script from this:
case "${1}" in
    post)
esac
To this:
#!/bin/sh
case $1/$2 in
  pre/*)
    echo "Going to $2..."
    # Place your pre suspend commands here, or `exit 0`
    # if no pre suspend action required
    sleep 1
  post/*)
    echo "Waking up from $2..."
    # Place your post suspend (resume) commands here, or `exit 0`
    # if no post suspend action required
    sleep 2
esac
For sure you are missing #!/bin/sh at the top of your script. Most of the rest of the proposed changes are not be necessary but informative.
I know this reply is a bit late, but I will post my method, maybe it will be useful to someone :-). !!! Only works with Xorg!!!.
The solution I found (a trick) is to create a script in /lib/systemd/system-sleep that stores a value ("1") in a file every time it wakes up from sleep, and I have another script that is always running that checks the contents of that file and when it is equal to "1" it runs the shell restart code and then changes the contents of the file to "0". The code to restart the shell is also a "trick" as I haven't found a command to do this, where I have to use xdotool to simulate keypress and mouse click.
Scripts:
  • /lib/systemd/system-sleep/resume_status
#!/bin/sh
if [ "${1}" == "post" ]; then sleep 5 echo "1" > PATH-TO-FILE/FILE fi
sleep 5 is used to wait the system to enter graphical environment
  • a user script to check the resume from sleep (placed somewhere in your HOME) :
#!/bin/bash
while true; do check=$(sed '1q;d' PATH-TO-FILE/FILE) if [[ "$check" == "1" ]]; then xdotool key alt+F2 sleep 1 xdotool click 1 xdotool type 'r' xdotool key Return echo "0" > PATH-TO-FILE/FILE fi sleep 5 done
Change PATH-TO-FILE/FILE to match your case and make sure xdotool is installed.
I have been using this method for a while now and it is working fine.
HayGuesty
