OS: Ubuntu desktop 18.04 LTS Linux version 4.15.0-24-generic
USB WiFi: odroid WiFi Module 3 with Realtek RTL8188CUS-GR
syslog has only ^@
Jul 4 12:31:50 udbv-HP-ProBook sudo: pam_ecryptfs: pam_sm_authenticate: /home/udbv is already mounted
Jul 4 12:33:30 udbv-HP-ProBook systemd-modules-load[396]: Inserted module 'ppdev'
Jul 4 12:33:30 udbv-HP-ProBook systemd-modules-load[396]: Inserted module 'parport_pc'
Jul 4 12:33:30 udbv-HP-ProBook systemd-cryptsetup[424]: crypt_init() failed: Block device required
Jul 4 12:33:30 udbv-HP-ProBook systemd[1]: Starting Flush Journal to Persistent Storage...
Jul 4 12:33:30 udbv-HP-ProBook swapon[415]: swapon: /swapfile: read swap header failed
Jul 4 12:33:30 udbv-HP-ProBook systemd[1]: Started Create Static Device Nodes in /dev.
Jul 4 12:33:30 udbv-HP-ProBook systemd[1]: Starting udev Kernel Device Manager...
Jul 4 12:33:30 udbv-HP-ProBook systemd[1]: Started Set the console keyboard layout.
Jul 4 12:33:30 udbv-HP-ProBook systemd[1]: Reached target Local File Systems (Pre).
Jul 4 12:33:30 udbv-HP-ProBook systemd[1]: Mounting Mount unit for vlc...
Jul 4 12:33:30 udbv-HP-ProBook systemd[1]: Mounting Mount unit for gnome-3-26-1604...
Jul 4 12:33:30 udbv-HP-ProBook systemd[1]: Mounting Mount unit for gnome-calculator...
Jul 4 12:33:30 udbv-HP-ProBook systemd[1]: Mounting Mount unit for pycharm-community...
Jul 4 12:33:30 udbv-HP-ProBook systemd[1]: Mounting Mount unit for skype, revision 41...
Jul 4 12:33:30 udbv-HP-ProBook systemd[1]: Mounting Mount unit for skype, revision 38...
Jul 4 12:33:30 udbv-HP-ProBook kernel: [ 0.000000] microcode: microcode updated early to revision 0x84, date = 2018-01-21
I tried following this guidance but it didn't help.
Any ideas?
