I am new to Ubuntu and recently I bought a new Dell Computer: Inspiron 13 5000 with 256 SSD, model i5379-5893GRY-PUS. I am trying to install Ubuntu.
I did try a lot of configurations, but none was successful. Things I already tried:
- Disable fast boot
powercfg off- AHCI enable
- Startup windows on safe mode and then restarting
- Disable security boot
- Partitioning on windows
I really don't know what else to try.
Commands:
$ fdisk -l
Disk /dev/loop0: 61.6 MiB, 64573440 bytes, 126120 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk /dev/loop1: 318.1 MiB, 333533184 bytes, 651432 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk /dev/loop2: 962 MiB, 1008779264 bytes, 1970272 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk /dev/loop3: 426.5 MiB, 447172608 bytes, 873384 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk /dev/sda: 7.4 GiB, 7948206080 bytes, 15523840 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0x4f4e129b Device Boot Start End Sectors Size Id Type /dev/sda1 * 64 3731283 3731220 1.8G cd unknown /dev/sda2 3731284 3739475 8192 4M ef EFI (FAT-12/16/32)
$ lsblk -f (DONE USING MANJARO)
NAME FSTYPE LABEL UUID MOUNTPOINT loop0 squashfs /run/miso/sfs/livefs loop1 squashfs /run/miso/sfs/mhwdfs loop2 squashfs /run/miso/sfs/desktopfs loop3 squashfs /run/miso/sfs/rootfs sda iso9660 MJR17110 2018-05-07-20-05-15-00 /run/miso/bootmnt ├─sda1 iso9660 MJR17110 2018-05-07-20-05-15-00 └─sda2 vfat MISO_EFI FDB1-353B
$ ls -ltr /dev/sda*
brw-rw---- 1 root disk 8, 0 Jul 4 05:36 /dev/sda brw-rw---- 1 root disk 8, 2 Jul 4 05:36 /dev/sda2 brw-rw---- 1 root disk 8, 1 Jul 4 05:36 /dev/sda1
$ ls -ltr /dev/loop*
brw-rw---- 1 root disk 7, 7 Jul 4 05:36 /dev/loop7 brw-rw---- 1 root disk 7, 6 Jul 4 05:36 /dev/loop6 brw-rw---- 1 root disk 7, 5 Jul 4 05:36 /dev/loop5 brw-rw---- 1 root disk 7, 4 Jul 4 05:36 /dev/loop4 brw-rw---- 1 root disk 7, 2 Jul 4 05:36 /dev/loop2 brw-rw---- 1 root disk 7, 1 Jul 4 05:36 /dev/loop1 brw-rw---- 1 root disk 7, 0 Jul 4 05:36 /dev/loop0 crw-rw---- 1 root disk 10, 237 Jul 4 05:36 /dev/loop-control brw-rw---- 1 root disk 7, 3 Jul 4 05:36 /dev/loop3
$ sudo lshw -C storage
*-usb:0
description: Mass storage device
product: USB Reader
vendor: ChipsBnk
physical id: 1
bus info: usb@1:1
logical name: scsi0
version: 1.00
serial: 110074973765
capabilities: usb-2.00 scsi emulated scsi-host
configuration: driver=usb-storage maxpower=100mA speed=480Mbit/s
*-storage UNCLAIMED
description: SATA controller
product: Sunrise Point-LP SATA Controller [AHCI mode]
vendor: Intel Corporation
physical id: 17
bus info: pci@0000:00:17.0
version: 21
width: 32 bits
clock: 66MHz
capabilities: storage msi pm ahci_1.0 cap_list
configuration: latency=0
resources: memory:d1230000-d1231fff memory:d1234000-d12340ff ioport:f090(size=8) ioport:f080(size=4) ioport:f060(size=32) memory:d1233000-d12337ff
