I tried customizing by using different customization tools and by removing different packages at different trials, but none of it worked properly!
The tools that I tried are Cubic, PinguyBuilder, optimizer, UCK, OS Builder.
What I want to do is to remove all packages given by Ubuntu and make a clean ISO image and what I tried is removed some packages like libreoffice related packages, firefox and then I generated an ISO image.
After that I installed it in Virtual-Machine but, it's not installing properly (sometimes saying installer crashed when libreOffice packages removed, sometimes blank-screen is appearing when any other packages removed, sometimes not even generating ISO).
is there any need of modifying some predefined files after removing/deleting some packages?
How can I create/generate that clean ISO image by removing all unwanted packages provided by Ubuntu?
One among other, Cubic, acronym for Custom Ubuntu ISO Creator, is a GUI application to create a customized bootable Ubuntu Live CD (ISO) image.
Cubic (Custom Ubuntu ISO Creator) is a GUI wizard to create a customized bootable Ubuntu Live CD (ISO) image. Cubic features an integrated command line chroot environment to make the customizations and permits effortless navigation, backward and forward, through the ISO generation steps. You can create new customization projects or modify existing projects. Important parameters are automatically populated with intelligent defaults to simplify the customization process.
See https://launchpad.net/cubic and many tutorials on internet.
ponsfrilus
  • 596
  • 17
Ubuntu itself has at least two ways to achieve what you want without using 3rd party tools:
Ubuntu Minimal Installation
Ubuntu now have a "minimal installation" option included in its installer. It installs the basic utilities (desktop environment, web browser, etc) leaving out packages such as LibreOffice, Thunderbird and Transmission.
Ubuntu MinimalCD
Ubuntu also offers a minimal ISO (only 64 MB!) which let you fully customize your system. Please note that this option may be a bit advanced for begginers.
You can also take a look at some non-Ubuntu options:
Arch Linux
A rolling-release Linux distribution whose default installation is a minimal base system. It is targeted at the proficient GNU/Linux user, or anyone with a do-it-yourself attitude who is willing to read the documentation, and solve their own problems.
Gentoo Linux
A metadistribution known by its extreme configurability and adaptability. Packages are usually compiled to be optimized as much as the user wants.
Linux From Scratch
Project that provides you with step-by-step instructions for building your own custom Linux system, entirely from source code. Although it is usually used for educational purposes, you can use the system you build on a daily basis.
nxnev
  • 351
