I'm following this tutorial for making an Ubuntu active directory domain controller with Samba.
The problem I have run into, is that he is using Ubuntu Server 13.10, and I am using the latest, 18.04. Somewhere between these 2 versions, Ubuntu stopped using /etc/network/interfaces and started using netplan.
Therefore, when he says to modify /etc/network/interfaces, and add:
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet static
address 192.168.2.100
netmask 255.255.255.0
network 192.168.2.0
broadcast 192.168.2.255
gateway 192.168.2.1
dns-nameservers 192.168.1.100 8.8.8.8
dns-search <domain name>.local
I get an error message that says:
ifupdown has been replaced by netplan(5) on this system.
I did some research, and found that now this should be stored in /etc/netplan/01-netcfg.yaml. This file does not exist. Should I create it? Also, what is the equivalent of what he said to put in the file, for netplan?
Edit: The output for ls /etc/netplan is 50-cloud-init.yaml, and the output for cat /etc/netplan/*.yaml is:
# This file is generated from information provided by
# the datasource. Changes to it will not persist across an instance.
# To disable cloud-init's network configuration capabilities, write a file
# /etc/cloud/cloud.cfg.d/99-disable-network-config.cfg with the following:
# network: {config: disabled}
network:
ethernets:
enp0s3:
addresses: []
dhcp4: true
optional: true
version: 2
