I suspect I may have a broken package system. I'm trying to install ROS and I get this output:
sudo apt-get install ros-kinetic-desktop-full
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies.
ros-kinetic-desktop-full : Depends: ros-kinetic-desktop but it is not going to be installed
Depends: ros-kinetic-perception but it is not going to be installed
Depends: ros-kinetic-simulators but it is not going to be installed
Depends: ros-kinetic-urdf-tutorial but it is not going to be installed
I arrived to this situation after having the same problem with a ros package. I spent a long time trying to install the dependencies of that package individually, removing conflicting packages and installing the required specific versions. But eventually I gave up as there were too many and decided to remove the whole ROS, then when I'm trying to reinstall it I get the error above.
I have tried all the formulas explained in this page to fix broken packages, but I can't resolve the problem. In in Ubuntu 16.04. Any suggestions? I've spent a lot of time with this an I'm about to reinstall Ubuntu as I don't know a better solution.
UPDATE
As explained in this answer I added
deb http://mirrors.ustc.edu.cn/ubuntu/ xenial main restricted universe multiverse
deb http://mirrors.ustc.edu.cn/ubuntu/ xenial-security main restricted universe multiverse
deb http://mirrors.ustc.edu.cn/ubuntu/ xenial-updates main restricted universe multiverse
deb http://mirrors.ustc.edu.cn/ubuntu/ xenial-proposed main restricted universe multiverse
deb http://mirrors.ustc.edu.cn/ubuntu/ xenial-backports main restricted universe multiverse
deb-src http://mirrors.ustc.edu.cn/ubuntu/ xenial main restricted universe multiverse
deb-src http://mirrors.ustc.edu.cn/ubuntu/ xenial-security main restricted universe multiverse
deb-src http://mirrors.ustc.edu.cn/ubuntu/ xenial-updates main restricted universe multiverse
deb-src http://mirrors.ustc.edu.cn/ubuntu/ xenial-proposed main restricted universe multiverse
deb-src http://mirrors.ustc.edu.cn/ubuntu/ xenial-backports main restricted universe multiverse
to /etc/apt/sources.list then try to install ros-kinetic-desktop-full again and it solved the problem! I'm not really sure why this worked though.
