I am installing doxygen using
sudo apt-get install doxygen
but getting following unmet dependencies. I tried with google but not getting proper solution for same.
I am getting this while run above code:
Reading package lists... Done
Building dependency tree
doxygen : Depends: libclang1-3.6 (>= 3.2) but it is not going to be installed
I am also tried with sudo apt-get install -f but no solution.
