I'm trying to add all of the anti-DDoSing rules from JavaPipe after removing UFW from my system and deleting all of the ufw chains (though the referenced answer didn't work. I had to run iptables -F and iptables -X with no parameters).
### 1: Drop invalid packets ###
/sbin/iptables -t mangle -A PREROUTING -m conntrack --ctstate INVALID -j DROP
### 2: Drop TCP packets that are new and are not SYN ###
/sbin/iptables -t mangle -A PREROUTING -p tcp ! --syn -m conntrack --ctstate NEW -j DROP
### 3: Drop SYN packets with suspicious MSS value ###
/sbin/iptables -t mangle -A PREROUTING -p tcp -m conntrack --ctstate NEW -m tcpmss ! --mss 536:65535 -j DROP
### 4: Block packets with bogus TCP flags ###
/sbin/iptables -t mangle -A PREROUTING -p tcp --tcp-flags FIN,SYN,RST,PSH,ACK,URG NONE -j DROP
/sbin/iptables -t mangle -A PREROUTING -p tcp --tcp-flags FIN,SYN FIN,SYN -j DROP
/sbin/iptables -t mangle -A PREROUTING -p tcp --tcp-flags SYN,RST SYN,RST -j DROP
/sbin/iptables -t mangle -A PREROUTING -p tcp --tcp-flags FIN,RST FIN,RST -j DROP
/sbin/iptables -t mangle -A PREROUTING -p tcp --tcp-flags FIN,ACK FIN -j DROP
/sbin/iptables -t mangle -A PREROUTING -p tcp --tcp-flags ACK,URG URG -j DROP
/sbin/iptables -t mangle -A PREROUTING -p tcp --tcp-flags ACK,FIN FIN -j DROP
/sbin/iptables -t mangle -A PREROUTING -p tcp --tcp-flags ACK,PSH PSH -j DROP
/sbin/iptables -t mangle -A PREROUTING -p tcp --tcp-flags ALL ALL -j DROP
/sbin/iptables -t mangle -A PREROUTING -p tcp --tcp-flags ALL NONE -j DROP
/sbin/iptables -t mangle -A PREROUTING -p tcp --tcp-flags ALL FIN,PSH,URG -j DROP
/sbin/iptables -t mangle -A PREROUTING -p tcp --tcp-flags ALL SYN,FIN,PSH,URG -j DROP
/sbin/iptables -t mangle -A PREROUTING -p tcp --tcp-flags ALL SYN,RST,ACK,FIN,URG -j DROP
### 5: Block spoofed packets ###
/sbin/iptables -t mangle -A PREROUTING -s 224.0.0.0/3 -j DROP
/sbin/iptables -t mangle -A PREROUTING -s 169.254.0.0/16 -j DROP
/sbin/iptables -t mangle -A PREROUTING -s 172.16.0.0/12 -j DROP
/sbin/iptables -t mangle -A PREROUTING -s 192.0.2.0/24 -j DROP
/sbin/iptables -t mangle -A PREROUTING -s 192.168.0.0/16 -j DROP
/sbin/iptables -t mangle -A PREROUTING -s 10.0.0.0/8 -j DROP
/sbin/iptables -t mangle -A PREROUTING -s 0.0.0.0/8 -j DROP
/sbin/iptables -t mangle -A PREROUTING -s 240.0.0.0/5 -j DROP
/sbin/iptables -t mangle -A PREROUTING -s 127.0.0.0/8 ! -i lo -j DROP
### 6: Drop ICMP (you usually don't need this protocol) ###
/sbin/iptables -t mangle -A PREROUTING -p icmp -j DROP
### 7: Drop fragments in all chains ###
/sbin/iptables -t mangle -A PREROUTING -f -j DROP
### 8: Limit connections per source IP ###
/sbin/iptables -A INPUT -p tcp -m connlimit --connlimit-above 111 -j REJECT --reject-with tcp-reset
### 9: Limit RST packets ###
/sbin/iptables -A INPUT -p tcp --tcp-flags RST RST -m limit --limit 2/s --limit-burst 2 -j ACCEPT
/sbin/iptables -A INPUT -p tcp --tcp-flags RST RST -j DROP
### 10: Limit new TCP connections per second per source IP ###
/sbin/iptables -A INPUT -p tcp -m conntrack --ctstate NEW -m limit --limit 60/s --limit-burst 20 -j ACCEPT
/sbin/iptables -A INPUT -p tcp -m conntrack --ctstate NEW -j DROP
### 11: Use SYNPROXY on all ports (disables connection limiting rule) ###
# Hidden - unlock content above in "Mitigating SYN Floods With SYNPROXY" section
### SSH brute-force protection ###
/sbin/iptables -A INPUT -p tcp --dport ssh -m conntrack --ctstate NEW -m recent --set
/sbin/iptables -A INPUT -p tcp --dport ssh -m conntrack --ctstate NEW -m recent --update --seconds 60 --hitcount 10 -j DROP
### Protection against port scanning ###
/sbin/iptables -N port-scanning
/sbin/iptables -A port-scanning -p tcp --tcp-flags SYN,ACK,FIN,RST RST -m limit --limit 1/s --limit-burst 2 -j RETURN
/sbin/iptables -A port-scanning -j DROP
When I type iptables -S after this, I only see a few of these rules.
# iptables -S
-P INPUT ACCEPT
-P FORWARD ACCEPT
-P OUTPUT ACCEPT
-N port-scanning
-A INPUT -p tcp -m connlimit --connlimit-above 111 --connlimit-mask 32 --connlimit-saddr -j REJECT --reject-with tcp-reset
-A INPUT -p tcp -m tcp --tcp-flags RST RST -m limit --limit 2/sec --limit-burst 2 -j ACCEPT
-A INPUT -p tcp -m tcp --tcp-flags RST RST -j DROP
-A INPUT -p tcp -m conntrack --ctstate NEW -m limit --limit 60/sec --limit-burst 20 -j ACCEPT
-A INPUT -p tcp -m tcp --dport 22 -m conntrack --ctstate NEW -m recent --set --name DEFAULT --mask 255.255.255.255 --rsource
-A INPUT -p tcp -m tcp --dport 22 -m conntrack --ctstate NEW -m recent --update --seconds 60 --hitcount 10 --name DEFAULT --mask 255.255.255.255 --rsource -j DROP
-A port-scanning -p tcp -m tcp --tcp-flags FIN,SYN,RST,ACK RST -m limit --limit 1/sec --limit-burst 2 -j RETURN
If I type iptables -t nat -L, I can see none of these rules.
# iptables -t nat -L
Chain PREROUTING (policy ACCEPT)
target prot opt source destination
Chain INPUT (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
Chain POSTROUTING (policy ACCEPT)
How do I get a list of all iptables rules for all tables?
