I am using Ubuntu family from 9.04 tile now 11.10.
I checked it's battery usage times and times and compared it with my windows.
In Ubuntu my battery get empty faster than windows.
At first, has any body else this problem or it is just for me?
And the second if it is true, what can we do to avoid this?
It is normal that laptops have a worse battery-time in Ubuntu. It's mainly because of the drivers you install; hardware companies control programs for drivers are (often) not open-source, so alternate versions are often worse. Also in Ubuntu 11.10 many battery-saving features are disabled because they don't work for some machines.
BrownE
  • 805
You could config the rc.local in /etc and add the following line before the exit:
sudo rfkill block bluetooth
so you deacitvate Bluetooth automatically. And there is a good program named Granola which reduces the battery consumption by undervolting your laptop when you use him for smaller things. If you run programs, that needs the power it automatically make the CPU-Voltage fitting.
So people seem to ask this a lot. Here's a link to several helpful suggestions. Basically you need laptop-mode-tools. Just installing that will probably improve your power consumption. You can compare how your laptop was doing before and after installing that, by installing powertop first and making some observations for a time.
Chan-Ho Suh
  • 7,582
  • 43
  • 74
