First, I am well aware of the numerous other posts, all of which I have read through many times, trying each of their solutions and variants of it, so please do not flag as duplicate or post links to them, I have seen them.
I believe this is more of a kernel issue (tried on both 4.16 and 4.17) more than a Ubuntu issue, as the same occurred on Arch when I was running that.
I have a relatively new ASUS FX503VM, which utilizes 2 CPU fans. It is detected as:
asus-isa-0000
Adapter: ISA adapter
cpu_fan:       0 RPM
And 0 is where it stays, and is always detected as. I have altered the div to various values including 4, 8, 16, 32, 128, etc, etc. Always 0, once in a while will be -1 after experimenting with various driver settings. The fan does not run, and all 4 cores are staying close to 60C, which is not cool, no pun intended. If the temps climb too high the, the BIOS kick in and run the fans to keep them from melting, but that's it. My BIOS do not have settings to adjust threshold, unfortunately.
I have tried the following:
  • acpi_enforce_resources=lax as a boot parameter
  • ncfs does nothing, just a different method of failing to read RPM
  • nct6775 driver
  • asus_fan (though I can't get modprobe to ever work, so I am unsure on the possible success of this option...)(I added to modules, did not get any reported errors, but it changed nothing)
  • pwmconfig is of no help, as it skips after trying to run the fan and nothing changes.
  • Flashed my BIOS to the newest available version (April, 2018)
  • Took control of the CPU governor with thermald, which helped to reduce temps about 10C, but does not solve the problem. I want the fans to run, not throttle back the CPU
  • Confirmed fans work, and RPM sensors work as I can see as much in the BIOS
I am at the end of the line of things to try, and am becoming more and more certain this is issue that cannot be solved with anything, basically just have incompatible hardware to run Linux. Does anyone have a solution I am missing, or have a ASUS FX503VM that can either confirm or deny that the CPU fans work as expected with this model?
