Whenever I try to do something in apt-get or apt, I always get this message:
Reading package lists... Done
Building dependency tree
Package 'nvidia-current' is not installed, so not removed
You might want to run 'apt --fix-broken install' to correct these.
libnvidia-ifr1-396 : Depends: libnvidia-gl-396 but it is not going to be installed
libnvidia-ifr1-396:i386 : Depends: libnvidia-gl-396:i386 but it is not going to be installed
nvidia-driver-396 : Depends: libnvidia-gl-396 (= 396.24.02-0ubuntu0~gpu18.04.1) but it is not going to be installed
Recommends: libnvidia-gl-396:i386 (= 396.24.02-0ubuntu0~gpu18.04.1)
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
Then, when I try apt --fix-broken install, it gives me:
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
lib32gcc1 libc6-i386
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
libnvidia-gl-396 libnvidia-gl-396:i386
The following NEW packages will be installed:
0 upgraded, 2 newly installed, 0 to remove and 72 not upgraded.
3 not fully installed or removed.
Need to get 0 B/32.3 MB of archives.
After this operation, 147 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 236145 files and directories currently installed.)
Preparing to unpack .../libnvidia-gl-396_396.24.02-0ubuntu0~gpu18.04.1_i386.deb ...
dpkg-query: no packages found matching libnvidia-gl-390
diversion of /usr/lib/i386-linux-gnu/libGL.so.1 to /usr/lib/i386-linux-gnu/libGL.so.1.distrib by nvidia-340
dpkg-divert: error: mismatch on package
when removing 'diversion of /usr/lib/i386-linux-gnu/libGL.so.1 by libnvidia-gl-396'
found 'diversion of /usr/lib/i386-linux-gnu/libGL.so.1 to /usr/lib/i386-linux-gnu/libGL.so.1.distrib by nvidia-340'
dpkg: error processing archive /var/cache/apt/archives/libnvidia-gl-396_396.24.02-0ubuntu0~gpu18.04.1_i386.deb (--unpack):
new libnvidia-gl-396:i386 package pre-installation script subprocess returned error exit status 2
Preparing to unpack .../libnvidia-gl-396_396.24.02-0ubuntu0~gpu18.04.1_amd64.deb ...
diversion of /usr/lib/x86_64-linux-gnu/libGL.so.1 to /usr/lib/x86_64-linux-gnu/libGL.so.1.distrib by nvidia-340
when removing 'diversion of /usr/lib/x86_64-linux-gnu/libGL.so.1 by libnvidia-gl-396'
found 'diversion of /usr/lib/x86_64-linux-gnu/libGL.so.1 to /usr/lib/x86_64-linux-gnu/libGL.so.1.distrib by nvidia-340'
dpkg: error processing archive /var/cache/apt/archives/libnvidia-gl-396_396.24.02-0ubuntu0~gpu18.04.1_amd64.deb (--unpack):
new libnvidia-gl-396:amd64 package pre-installation script subprocess returned error exit status 2
I also tried to sudo dpkg --configure -a, but it also gives me an error:
dpkg: dependency problems prevent configuration of nvidia-driver-396:
nvidia-driver-396 depends on libnvidia-gl-396 (= 396.24.02-0ubuntu0~gpu18.04.1); however:
Package libnvidia-gl-396:amd64 is not installed.
dpkg: error processing package nvidia-driver-396 (--configure):
dependency problems - leaving unconfigured
Processing triggers for libc-bin (2.27-3ubuntu1) ...
dpkg: dependency problems prevent configuration of libnvidia-ifr1-396:amd64:
libnvidia-ifr1-396:amd64 depends on libnvidia-gl-396; however:
dpkg: error processing package libnvidia-ifr1-396:amd64 (--configure):
dpkg: dependency problems prevent configuration of libnvidia-ifr1-396:i386:
libnvidia-ifr1-396:i386 depends on libnvidia-gl-396; however:
Package libnvidia-gl-396:i386 is not installed.
dpkg: error processing package libnvidia-ifr1-396:i386 (--configure):
nvidia-driver-396
I also can't change from driver nvidia-driver-396 ti the nouveau driver.
How can I fix this? I'm on Ubuntu 18.04.
