22
I am on Ubuntu 18.04 LTS and I am trying to set up Android Studio for the first time. When I run my simple "Hello World" app, it gives me a pop-up that says
KVM is required to run this AVD.
Unknown Error
Please file a bug against Android Studio
popup
But when I run simply kvm-ok it outputs:
INFO: /dev/kvm exists
KVM acceleration can be used
Zanna
  • 72,312
Nomi Shaw
  • 455
5 Answers5
35
Starting with Ubuntu 18.04 and Linux Mint Tara you need to install qemu-kvm
sudo apt install qemu-kvm
Check the ownership of /dev/kvm
ls -al /dev/kvm
Check which users are in the kvm group
grep kvm /etc/group
Output from the above command
kvm:x:some_number:
If there is nothing rightwards of the final :, there are no users in the kvm group.
To add the current user to the kvm group
sudo adduser $USER kvm
which adds the user to the group, and check once again with grep kvm /etc/group.
A restart may be required for the permissions to take effect.
Official answer on StackOverflow
Kulfy
  • 18,154
Change sdk emulator folder permission. This is worked for me.
chmod 777 -R {sdk folder}/emulator
https://stackoverflow.com/questions/44635879/kvm-is-required-to-run-this-avd-unknown-error-please-file-a-bug-against-androi
To run KVM, you need a processor that supports hardware virtualization.
To see if your processor supports hardware virtualization, you can review the output from this command:
egrep -c '(vmx|svm)' /proc/cpuinfo
  • If 0 it means that your CPU doesn't support hardware virtualization.
  • If 1 or more it does - but you still need to make sure that virtualization is enabled in the BIOS.
Installation of KVM
Cosmic (18.10) or later
sudo apt-get install qemu-kvm libvirt-daemon-system libvirt-clients bridge-utils
You need to ensure that your username is added to the group libvirtd, and kvm:
sudo adduser `id -un` libvirt
sudo adduser `id -un` kvm
Verify Installation
Run kvm-ok on the command line.
$ kvm-ok
Logout or restart for changes to take effect.
Sources:
https://developer.android.com/studio/run/emulator-acceleration#accel-check https://help.ubuntu.com/community/KVM/Installation
Gayan Weerakutti
  • 3,830
  • 28
  • 39
-1
I usually run
sudo chown username -R /dev/kvm
but this is only good for a while. Looking for a better solution.
There is also another command:
sudo adduser username kvm
ADNow
  • 99
-1
Login as a root user sudo su goto the studio installation dir withcd ${path_of _installation_dir}/android-studio/bin and relaunch the sdk with ./studio.sh. Then try relaunching your avd
Rohit
  • 99
