Went to Ubuntu Software installed Samba 1.2.63-0ubuntu6.
Clicked 'Launch'... nothing happens
Does not show up in 'Show Applications'
I had the same exact issue. To fix it I ran:
sudo system-config-samba
The very last line of the output read:
SystemError: could not open configuration file '/etc/libuser.conf': No such file or directory
I simply created the file by using:
sudo touch /etc/libuser.conf
and it worked fine.
I couldn't seem to get it to appear in the application screen, but can be run by
from the terminal.
The previous answer will get it working but there is a way to fix it not showing up on the applications screen.
gksu is one of the dependencies of samba. gksu was removed from the Ubuntu package library in 18.04 This is the reason samba doesn't show up in the applications screen.
One way to fix this is to install the version of gksu used in Ubuntu 17.10
To do this folow these instructions (from here https://askubuntu.com/a/1030066)
Add artful repositories to the system:
cat <<EOF | sudo tee /etc/apt/sources.list.d/artful.list
deb http://archive.ubuntu.com/ubuntu/ artful universe
EOF
Update package cache
sudo apt-get update
Install gksu package
sudo apt-get install gksu
Remove artful repository from system for safety
sudo rm /etc/apt/sources.list.d/artful.list
sudo apt-get update
After youv'e done this uninstall samba from the command line using:
sudo apt autoremove samba
Then install samba again from the Ubuntu software center.
It is important that you install it from the Ubuntu software center and not from the command line. It wont work if you do it from the command line. I have no idea why, it just doesn't.
Samba should now show up in the applications screen.
For those who don't mind typing password in terminal the easiest way to replace the shortcut to samba is to edit the .desktop file. In my case on Xubuntu it's located in /usr/share/applications/ and ~/.local/share/applications/
Just edit the file system-config-samba.desktop or samba.desktop with a text editor, and replace the line
Exec=gksu system-config-samba
with
Exec=sudo system-config-samba
and the line:
Terminal=False
to
Terminal=true
I simply do sudo system-config-samba and all is working fine. The Samba GUI is shown as expected.
