I have had the same issue, and tried using autofs and startup commands, and others, with unsatisfactory results. I finally solved it by writing my own script that I add as an Autostart script. This script requires python and that the user has sudo privileges (without a password) for at least the mount command.
Here is the Python script (main.py):
Code to do a user level mounts/unmounts
Usage:
python3 main.py mount|unmount
The mounts list contains the information needed to perform the mount and unmount.
These mounts should not appear in the /etc/fstab file.
each element of the mounts list is itself a list in the format:
[device, mount_dir, mount_options, ...]
where `device` is the device to be mounted such as '//192.168.1.3/Public'
'mount_dir' is the mount point
'mount_options' is the options to be used by the mount command.
Each option must be an element itself.
for example: '-t', 'cifs', '-o', 'rw,users,noperm,guest,soft,cache=none,sec=none'
Edit the `mounts` list to your needs.
The mount command issued will be 'sudo mount <mount_options> <device> <mount_dir>`.
The unmount command will be `sudo umount <mount_dir>`.
This requires that the user be in the `sudoers` group with the
"NOPASSWD" argument, for example:
jra ALL=(ALL) NOPASSWD: ALL
gives user `jra` the ability to use the `sudo` command without ever
providing a password. (This can be modified to limit
the commands allowed without a password).
Upon start of this script, attempts will be made to mount each element
in the mounts list.
Failed mounts are added to the `waiting_mounts` list, and mounts for
those failures are retried after delays specified in 'SLEEP_SECONDS' list.
Unmounting is performed by the OS, normally not by this script.
A log directory `.simpleAutomount` is created in the users home directory.
import subprocess
import time
import sys
from datetime import datetime
import os.path
import shutil
# this is the list of mounts to be performed (list of lists)
mounts=[
['//192.168.1.3/Public', '/mnt/mybook', '-t', 'cifs', '-o', 'rw,_netdev,users,noperm,guest,soft,cache=none,sec=none,vers=1.0' ],
# ['/dev/sda4', '/windows', '-t', 'ntfs']
SLEEP_SECONDS = [5, 5, 5, 10, 20, 100, 100] # number of seconds to sleep between successive mount attempts
MAX_TRIES = len(SLEEP_SECONDS)
waiting_mounts = []
def ping(host):
ping the specified host and return the exit value of the ping
success == 0 means success
success == 1 means no reply received
success == 2 means no network available
cmd = ['ping', host, '-c 1']
success = subprocess.call(cmd, stdout=subprocess.PIPE)
return success
def process_mount(mnt):
attempt to perform one mount as indicated in the mnt list
:param mnt: one element from the mounts list (which is a list in itself)
:return: True if the mount was successful (or the mount should not be attempted again). False if the mount should be tried again later
host = None
if mnt[0].startswith('//'): # format is //host/directory
index = mnt[0].index('/', 2)
host = mnt[0][2:index]
elif ':' in mnt[0]: # format is host:directory
index = mnt[0].index(':')
host = mnt[0][:index]
mnt_cmd = ['sudo', 'mount']
mnt_cmd.extend(mnt[2:])
mnt_cmd.extend(mnt[0:2])
if host is None: # this is not a network mount, do not need to ping
logFile.write('running ' + str(mnt_cmd) + '\n')
logFile.flush()
returnCode = subprocess.call(mnt_cmd)
logFile.write('\t' + str(mnt_cmd) + ' finished with return code: ' + str(returnCode) + '\n')
logFile.flush()
return True
elif ping(host) == 0:
logFile.flush()
logFile.flush()
return True
else:
return False
def usage(unrecognized_opt=None):
if unrecognized_opt is not None:
print('Unrecognized option: ' + str(unrecognized_opt) + '\n')
logFile.write('Unrecognized option: ' + str(unrecognized_opt) + '\n')
print('usage:\n\tpython3 ' + sys.argv[0] + ' mount|unmount\n')
logFile.write('usage:\n\tpython3 ' + sys.argv[0] + ' mount|unmount\n')
logFile.flush()
if __name__ == '__main__':
The starting point for the SimpleAutomount script
Legal arguments are 'mount' or 'unmount'
'mount' will inspect each element of the mounts list and attempt the mounts
'unmount' will attempt to unmount each element of the mount list
if len(sys.argv) != 2:
usage()
sys.exit(1)
theDate = datetime.now()
# create a log file in the users ~/.simpleAutomount directory
home = os.path.expanduser("~")
sam = os.path.join(home, '.simpleAutomount')
if not os.path.exists(sam):
os.mkdir(sam, 0o755)
logFileName = os.path.join(sam, "simpleAutomount.log")
logFile = open(logFileName, 'a')
# start logging
logFile.write('\n\nSimpleAutomount started at ' + str(theDate) + ' with arg: ' + sys.argv[1] + '\n')
logFile.flush()
if sys.argv[1].lower() == 'mount': # do mount
os.spawnlp(os.P_NOWAIT, sys.executable, sys.executable, sys.argv[0], 'forked_mount') # fork so that systemd does not wait and delay login
sys.exit(0) # indicate success
elif sys.argv[1].lower() == 'forked_mount': # we are forked, so we can take our time here
for mnt in mounts:
if not process_mount(mnt): # the mount was not successful and should be tried again later
logFile.write('appending ' + mnt[0] + ' to waiting mounts\n')
logFile.flush()
waiting_mounts.append((mnt)) # add this mount to the waiting_mounts list to be tried again later
# if any mounts were unsuccessful and should be tried again, loop to try mounting again
try_count = 0
while len(waiting_mounts) > 0 and try_count < MAX_TRIES:
logFile.write('sleeping for ' + str(SLEEP_SECONDS[try_count]) + ' seconds\n')
logFile.flush()
time.sleep(SLEEP_SECONDS[try_count])
# process waiting_mounts, starting at the end for ease of deletion
indx = len(waiting_mounts) - 1
for i in range(indx, -1, -1):
mnt = waiting_mounts[i]
logFile.write('Attempting to mount ' + mnt[0] + ' for try number ' + str(try_count) + '\n')
logFile.flush()
# try this mount again
if process_mount(mnt):
del waiting_mounts[i] # mount was successful, so remove this entry from waiting mounts
try_count += 1
logFile.write('SimpleAutomount exiting with ' + str(len(waiting_mounts)) + ' remaining unmounted\n')
elif sys.argv[1].lower() == 'unmount': # do unmount
for mnt in mounts:
cmd = ['sudo', 'umount', mnt[1]]
#journal.send('running ' + str(cmd), SYSLOG_IDENTIFIER='simple_automount', SYSLOG_PID=str(os.getpid()))
logFile.write('running ' + str(cmd) + '\n')
logFile.flush()
returnCode = subprocess.call(cmd)
logFile.write('\t' + str(cmd) + ' finished with return code: ' + str(returnCode) + '\n')
logFile.flush()
sys.exit(0)
else:
usage(unrecognized_opt=sys.argv[1])
sys.exit(1)
