First, I am new to Linux and Ubuntu.
I obtained the following directions from a CFD website:
"Hey Alex,
I just had the same problem as you did, but a friend of mine found a fix. It is likely that salome forgot to update a dependency in the new version (8.4.0), libjasper.so.1 in fact. You can download it from: http://ece.uvic.ca/~frodo/jasper/#download , where you should download jasPer 1.900.22 (the later ones have a different system). If you then compile it and add the generated libjasper.so.1 to the path it works like a charm ;)
hopefully this is enough to fix the problem, but it would be better if salome added the dependency in the next update or so. Good luck!"
I am having the same problem and would like detailed instructions on how to implement the above suggestion. I have never complied on Linux, Ubuntu, etc.
In addition to compiling, I have to add to a "library" and that is not explained in other tutorials.
Look in the "docs" directory, there's a file called "jasper.pdf". In serction 2.4.1 there are instructions for building and installing on Linux:
$ ./configure
$ make
$ sudo make install
The last command (sudo make install) should copy the libjasper.so to the appropriate directory. If it doesn't, just manually copy it to /usr/lib:
$ sudo cp `find ./ -name 'libjasper.so'` /usr/lib/
BTW: You're probably better off asking such questions (about building software) in StackOverflow.
