I am trying to install TensorRT before installing TensorFlow 1.8 from source. When I follow the documentation given here, I run into an error when installing TensorRT 4.0. The error I get is:
nivedithak@nivii-Sum18:~/Downloads$ sudo apt-get install tensorrt
[sudo] password for nivedithak:
Reading package lists... Done
Building dependency tree
 tensorrt : Depends: libnvinfer4 (>= 4.1.2) but it is not going to be installed
            Depends: libnvinfer-dev (>= 4.1.2) but it is not going to be installed
            Depends: libnvinfer-samples (>= 4.1.2) but it is not going to be installed
When I use
nivedithak@nivii-Sum18:~/Downloads$ apt-mark showhold
I don't see any packages. I am not sure how to get ahead. I am using CUDA 9.0 with cuDNN 7.0.5.
I had the same issue.
Environment
  • ubuntu 16.04
  • cuda 9.0
Solution:
I think that you may install the cuda by .run file. If that's true, u should remove it and reinstall cuda by .deb file.
run
dpkg-query -W | grep cuda-cublas
then if outputs is something like this :
cuda-cublas-9-0 9.0.176-1
cuda-cublas-dev-9-0 9.0.176-1
then your issue will be solved.
Stephen Rauch
  • 1,156
  • 15
Same issue when install TensorRT 6.0.1.5 by deb with Ubuntu 16.04 and CUDA 10.1.
The other answer doesn't work for me, but I followed @Terrance's comment:
Maybe try installing CUDA for 16.04 this way first: https://askubuntu.com/a/1025949/231142 which does install the missing dependencies of cuda-cublas that you are showing.
After I reinstalled CUDA, TensorRT can be installed smoothly without any error. However, when I tried import tensorrt in python, I got the module not found error. This is solved in ImportError: No module named 'tensorrt'.
Lorenz Keel
  • 9,511
