I tried to create a Windows 10 USB boot medium with WoeUSB. I formatted a USB drive with an NTFS partition, but WoeUSB complains with:
Installation failed!
Exit code: 256
Log:
WoeUSB v@@WOEUSB_VERSION@@
Mounting source filesystem...
Wiping all existing partition table and filesystem signatures in /dev/sdc... wipefs:
error: /dev/sdc: probing initialization failed The command "wipefs --all
"${target_device}"" failed with exit status "1", program is prematurely aborted
Unmounting and removing "/medi/woeusb_source_1530017199_18199"...
You may now safely detach the target device
or
 wipefs: WARNING: /dev/sdc: appears to contain 'dos' partition table
karel
  • 122,292
  • 133
  • 301
  • 332
jschnasse
  • 391
dont eject just unmount.
this is what worked:
  1. insert usb stick
  2. open gparted
  3. unmount using gparted
  4. format to ntfs using gparted
  5. close gparted
  6. Use woeusb, it should work now
hth
  • 81
Start wousb from command line:
sudo woeusb --partition Win10_1803_EnglishInternational_x64.iso /dev/sdc1
jschnasse
  • 391
sudo wipefs --all --force /dev/sdX
You'll need to change /dev/sdX to your device
Below steps worked for me for windows 7 bootable pendrive in ubuntu-18.04
Step 1: Download the latest bash file from the release of the WoeUSB page https://github.com/WoeUSB/WoeUSB/releases
Step 2: Fix the missing executable file permission chmod +x path/to/woeusb-N.N.N.bash
Step 3: Install GParted sudo apt-get install gparted
Step 4: Start gparted ui interface
Step 5: Select your drive by top-right dropdown delete your whole partition using GParted ( Don't create a new partition after that )
Step 6: Make bootable Pendrive ( sudo ./woeusb-N.N.N.bash --target-filesystem NTFS --device path/to/windows.iso /dev/sdX )
 wget https://github.com/WoeUSB/WoeUSB/releases
sudo apt install gparted cp /home/devops/Downloads/woeusb-5.2.4.bash .
chmod 777 woeusb-5.2.4.bash sudo ./woeusb-5.2.4.bash --target-filesystem NTFS --device /home/devops/Downloads/test/en_windows_7_ultimate_x64_dvd.iso /dev/sdb
sudo apt install wimtools
Install above package if you get below error and then rerun woeusb command below it again
"error woeusb requires wimlib-imagex command in the executable search path, but it is not found"
