I'm trying to install Spotify on my Lubuntu following this guide: https://www.spotify.com/ar/download/linux/.
But neither of the methods work.
With snap I get on console error: snap "spotify" not found.
And with the deb package I get
 spotify-client : Depends: libcurl3 but it is not going to be installed
                  Recommends: libavcodec-ffmpeg56 but it is not installable or
                              libavcodec-ffmpeg-extra56 but it is not installable or
                              libavcodec54 but it is not installable or
                              libavcodec-extra-54 but it is not installable
                  Recommends: libavformat-ffmpeg56 but it is not installable or
                              libavformat54 but it is not installable
What can I do to install Spotify in Lubuntu 18.04? I was able to install it with snap on Kubuntu 18.04 about a month ago.
amaralli
  • 111
Did you intall the restricted extra for lubuntu? the missing depenencies may be codecs.
Try this first then reinstall Spotify
sudo apt-get update
sudo apt-get install lubuntu-restricted-extras
sudo apt-get install lubuntu-restricted-addons
pomsky
  • 70,557
