How to remove old kernels in Grub2, including files.
Using the Disk Usage Analyzer, I found that the Linux kernels are located in 4 areas of the root directory: /boot /lib/firmware /lib/modules /usr/src
All we have to do is, go to each directory and remove the files or directories that are not needed.
Use the command [rm] for files and [rm -r] for directories. You have to use [sudo su] to have administrative account, or use [sudo (command)] to invoke administrative command.
For our example, we will use the linux kernel version 4.4.0-112 You can choose which version you will remove.
at /boot = kernels are all files : abi-4.4.0-112-generic config-4.4.0-112-generic initrd.img-4.4.0-112-generic retpoline-4.4.0-112-generic System.map-4.4.0-112-generic vmliniz-4.4.0-112-generic
(note: not all kernel versions have these files included above)
at /lib/firmware = kernels are in subdirectories : 4.4.0-112-generic
at /lib/modules = kernels are in subdirectories : 4.4.0-112-generic
at /usr/src = kernels are in subdirectories : linux-headers-4.4.0-112 linux-headers-4.4.0-112-generic
Now all we need to do is use the command [update-grub]
This will free your hard disk around 300MB worth of disk space for every kernel that you will remove.
Please note that I am using Ubuntu 16.04 Xenial.
And if anybody knows how to delete files in GUI, please let me know, it would be alot easier.
sudo apt autoremove will do the trick.
It will leave the two most recent kernels, and remove the rest. It will also remove other packages that are not needed any more, that is packages that was automatically installed as dependencies to other packages that has later been uninstalled.
Soren A
  • 7,191
Ubuntu before 18.04
List old kernel(s):
dpkg -l 'linux-*' | sed '/^ii/!d;/'"$(uname -r | sed "s/\(.*\)-\([^0-9]\+\)/\1/")"'/d;s/^[^ ]* [^ ]* \([^ ]*\).*/\1/;/[0-9]/!d'
Uninstall old kernel(s):
dpkg -l 'linux-*' | sed '/^ii/!d;/'"$(uname -r | sed "s/\(.*\)-\([^0-9]\+\)/\1/")"'/d;s/^[^ ]* [^ ]* \([^ ]*\).*/\1/;/[0-9]/!d' | xargs sudo apt-get -y purge
Ubuntu 18.04 and later
since 18.04, this two liner should be applied as the previous one liner may uninstall other packages
dpkg --list | grep 'linux-image' | awk '{ print $2 }' | sort -V | sed -n '/'"$(uname -r | sed "s/\([0-9.-]*\)-\([^0-9]\+\)/\1/")"'/q;p' | xargs apt-get -y purge
dpkg --list | grep 'linux-headers' | awk '{ print $2 }' | sort -V | sed -n '/'"$(uname -r | sed "s/\([0-9.-]*\)-\([^0-9]\+\)/\1/")"'/q;p' | xargs apt-get -y purge
Uninstalling of kernel will run the grub reconfigure process
cmak.fr
  • 8,976
Uninstall the kernels you no longer need using your package manager, this will take care of the files as well as the grub entries, as long as you haven’t made manual changes like custom entries and custom files.
