Was trying to install "unity-tweak-tool" and get:
$ sudo apt-get install unity-tweak-tool
Reading package lists... Done
Building dependency tree
 unity-tweak-tool : Depends: unity-webapps-common but it is not going to be installed
Did some research and ran:
sudo apt-get --fix-broken install
0 to upgrade, 0 to newly install, 0 to remove and 1 not to upgrade.
then sudo apt-get dist-upgrade
but to no effect, so still got the problem of finding a way to backtrack to the cause of the dependencies. So tried aptitude and got:
sudo aptitude install unity-tweak-tool
The following NEW packages will be installed:
  libhardware2{a} libhybris{a} libhybris-common1{a} libmedia1{a}
  liboxideqt-qmlplugin{a} liboxideqtcore0{ab} liboxideqtquick0{a}
  libqt5organizer5{ab} libubuntugestures5{ab} libubuntutoolkit5{ab}
  libunity-webapps0{a} qml-module-ubuntu-components{ab}
  qml-module-ubuntu-layouts{ab} qml-module-ubuntu-test{ab}
  qml-module-ubuntu-web{a} qtdeclarative5-ubuntu-ui-toolkit-plugin{a}
  unity-tweak-tool unity-webapps-common{a} unity-webapps-qml{a}
  unity-webapps-service{a} webapp-container{ab} webbrowser-app{ab}
0 packages upgraded, 22 newly installed, 0 to remove and 0 not to upgrade.
Need to get 36.9 MB of archives. After unpacking 145 MB will be used.
 qml-module-ubuntu-test : Depends: qtbase-abi-5-5-1 which is a virtual package, provided by:
                                    - libqt5core5a, but 5.10.0+dfsg-2+16.04+xenial+build46 is installed.                                    - libqt5core5a, but 5.10.0+dfsg-2+16.04+xenial+build46 is installed.
 liboxideqtcore0  : Depends: qtbase-abi-5-5-1 which is a virtual package, provided by:
 libqt5organizer5 : Depends: qtbase-abi-5-5-1 which is a virtual package, provided by:
 webapp-container : Depends: qtbase-abi-5-5-1 which is a virtual package, provided by:
                    Depends: qtdeclarative-abi-5-5-0 which is a virtual package, provided by:
                              - libqt5qml5, but 5.10.0-0neon+16.04+xenial+build36 is installed.
 qml-module-ubuntu-layouts : Depends: qtdeclarative-abi-5-5-0 which is a virtual package, provided by:
 qml-module-ubuntu-components : Depends: qtbase-abi-5-5-1 which is a virtual package, provided by:
 libubuntutoolkit5 : Depends: qtbase-abi-5-5-1 which is a virtual package, provided by:
 webbrowser-app : Depends: qtbase-abi-5-5-1 which is a virtual package, provided by:
 libubuntugestures5 : Depends: qtdeclarative-abi-5-5-0 which is a virtual package, provided by:
The following actions will resolve these dependencies:
      Keep the following packages at their current version:
1)      liboxideqt-qmlplugin [Not Installed]
2)      liboxideqtcore0 [Not Installed]
3)      liboxideqtquick0 [Not Installed]
4)      libqt5organizer5 [Not Installed]
5)      libubuntugestures5 [Not Installed]
6)      libubuntutoolkit5 [Not Installed]
7)      libunity-webapps0 [Not Installed]
8)      qml-module-ubuntu-components [Not Installed]
9)      qml-module-ubuntu-layouts [Not Installed]
10)     qml-module-ubuntu-test [Not Installed]
11)     qml-module-ubuntu-web [Not Installed]
12)     qtdeclarative5-ubuntu-ui-toolkit-plugin [Not Installed]
13)     unity-tweak-tool [Not Installed]
14)     unity-webapps-common [Not Installed]
15)     unity-webapps-qml [Not Installed]
16)     unity-webapps-service [Not Installed]
17)     webapp-container [Not Installed]
18)     webbrowser-app [Not Installed]
Accept this solution? [Y/n/q/?] Y
No packages will be installed, upgraded, or removed.
0 packages upgraded, 0 newly installed, 0 to remove and 0 not to upgrade.
Need to get 0 B of archives. After unpacking 0 B will be used.
Attempting to work back through the dependencies, by installing manually also ran into issues with "libqt5core5a" when running aptitude install liboxideqtquick0 wanting to uninstall libmlt++3, libmlt6, libqt5webchannel5, melt, openshot, python-mlt and qt5-gtk-platformtheme.
Any help tracking down a solution very much appreciated.
Further to request for further info:
As there is some major lags in pkgs getting updated, the following have been added to get the latest versions of pkgs or install pkgs not in the main repositories. So, to be comprehensive I include the following.
I used a script to extract a list of the repos and PPAs:
The following are self explanatory:
'http://archive.ubuntu.com/ubuntu xenial main restricted'
'http://archive.ubuntu.com/ubuntu xenial-updates main restricted'
'http://archive.ubuntu.com/ubuntu xenial universe'
'http://archive.ubuntu.com/ubuntu xenial-updates universe'
'http://archive.ubuntu.com/ubuntu xenial multiverse'
'http://archive.ubuntu.com/ubuntu xenial-updates multiverse'
'http://archive.ubuntu.com/ubuntu xenial-backports main restricted universe multiverse'
'http://archive.canonical.com/ubuntu xenial partner'
'http://archive.ubuntu.com/ubuntu xenial-security main restricted'
'http://archive.ubuntu.com/ubuntu xenial-security universe'
'http://archive.ubuntu.com/ubuntu xenial-security multiverse'
'http://deb.torproject.org/torproject.org xenial main'
'https://dl.winehq.org/wine-builds/ubuntu/ xenial main'
'https://download.virtualbox.org/virtualbox/debian xenial contrib'
These are to get the latest versions OR add functionality:
ppa:stebbins/handbrake-releases
ppa:maarten-baert/simplescreenrecorder
ppa:webupd8team/nemo3   # latest version of nemo file browser
ppa:linrunner/tlp
ppa:mc3man/mpv-tests
ppa:elementary-os/stable
ppa:bablu-boy/nutty
ppa:jfi/ppa
ppa:audio-recorder/ppa
ppa:noobslab/themes
ppa:hda-me/zulucrypt
ppa:scribus/ppa
ppa:plushuang-tw/uget-stable
ppa:mc3man/xerus-media
ppa:unit193/encryption
ppa:noobslab/icons
ppa:jeffreyratcliffe/ppa
'http://repo.vivaldi.com/stable/deb/ stable main'   # Vivaldi Web Browser
Now a detailed list of the installed pkgs from the PPAs, which I extracted using the following script:
apt-cache policy $(dpkg --get-selections | grep -v deinstall$ | awk '{ print $1 }') | perl -e '@a = <>; $a=join("", @a); $a =~ s/\n(\S)/\n\n$1/g;  @packages = split("\n\n", $a); foreach $p (@packages) {print "$1: $2\n" if $p =~ /^(.*?):.*?500 http:\/\/ppa\.launchpad\.net\/(.*?)\s/s}'
albatross-theme: noobslab/themes/ubuntu
ashes-theme: noobslab/themes/ubuntu
audio-recorder: audio-recorder/ppa/ubuntu
cinnamon-l10n: webupd8team/nemo3/ubuntu
com.github.babluboy.nutty: bablu-boy/nutty/ubuntu
contractor: elementary-os/stable/ubuntu
cryptsetup: unit193/encryption/ubuntu
cryptsetup-bin: unit193/encryption/ubuntu
faba-icon-theme: noobslab/icons/ubuntu
faenza-icon-theme: noobslab/icons/ubuntu
faience-icon-theme: noobslab/icons/ubuntu
ffmpeg: mc3man/xerus-media/ubuntu
gir1.2-nemo-3.0: webupd8team/nemo3/ubuntu
gscan2pdf: jeffreyratcliffe/ppa/ubuntu
handbrake-cli: stebbins/handbrake-releases/ubuntu
handbrake-gtk: stebbins/handbrake-releases/ubuntu
i965-va-driver: mc3man/mpv-tests/ubuntu
libavcodec-extra: mc3man/xerus-media/ubuntu
libavcodec-extra57: mc3man/xerus-media/ubuntu
libavcodec-ffmpeg-extra56: mc3man/xerus-media/ubuntu
libavdevice-ffmpeg56: mc3man/xerus-media/ubuntu
libavdevice57: mc3man/xerus-media/ubuntu
libavfilter-ffmpeg5: mc3man/xerus-media/ubuntu
libavfilter6: mc3man/xerus-media/ubuntu
libavformat-ffmpeg56: mc3man/xerus-media/ubuntu
libavformat57: mc3man/xerus-media/ubuntu
libavresample-ffmpeg2: mc3man/xerus-media/ubuntu
libavresample3: mc3man/xerus-media/ubuntu
libavutil-ffmpeg54: mc3man/xerus-media/ubuntu
libavutil55: mc3man/xerus-media/ubuntu
libbasicusageenvironment1: mc3man/xerus-media/ubuntu
libcryptsetup4: unit193/encryption/ubuntu
libfdk-aac1: mc3man/xerus-media/ubuntu
libglib-object-introspection-perl: jeffreyratcliffe/ppa/ubuntu
libgoocanvas2-perl: jeffreyratcliffe/ppa/ubuntu
libgranite-common: elementary-os/stable/ubuntu
libgranite4: elementary-os/stable/ubuntu
libgroupsock8: mc3man/xerus-media/ubuntu
libgtk3-perl: jeffreyratcliffe/ppa/ubuntu
libgtk3-simplelist-perl: jeffreyratcliffe/ppa/ubuntu
libimage-sane-perl: jeffreyratcliffe/ppa/ubuntu
liblirc-client0: mc3man/xerus-media/ubuntu
liblircclient0: mc3man/xerus-media/ubuntu
liblivemedia58: mc3man/xerus-media/ubuntu
libmysofa: mc3man/mpv-tests/ubuntu
libnemo-extension1: webupd8team/nemo3/ubuntu
libpostproc-ffmpeg53: mc3man/xerus-media/ubuntu
libpostproc54: mc3man/xerus-media/ubuntu
libqxp-0.0-0: scribus/ppa/ubuntu
libswresample-ffmpeg1: mc3man/xerus-media/ubuntu
libswresample2: mc3man/xerus-media/ubuntu
libswscale-ffmpeg3: mc3man/xerus-media/ubuntu
libswscale4: mc3man/xerus-media/ubuntu
libusageenvironment3: mc3man/xerus-media/ubuntu
libva-drm1: mc3man/mpv-tests/ubuntu
libva-x11-1: mc3man/mpv-tests/ubuntu
libva1: mc3man/mpv-tests/ubuntu
libvlc-bin: mc3man/xerus-media/ubuntu
libvlc5: mc3man/xerus-media/ubuntu
libvlccore8: mc3man/xerus-media/ubuntu
libx264-148: mc3man/xerus-media/ubuntu
libx264-152: mc3man/xerus-media/ubuntu
libx265-130: mc3man/xerus-media/ubuntu
libx265-146: mc3man/xerus-media/ubuntu
libxapp1: webupd8team/nemo3/ubuntu
libzimg2: mc3man/xerus-media/ubuntu
libzmf-0.0-0: scribus/ppa/ubuntu
libzulucrypt1: hda-me/zulucrypt/ubuntu
mpv: mc3man/mpv-tests/ubuntu
nemo: webupd8team/nemo3/ubuntu
nemo-data: webupd8team/nemo3/ubuntu
nemo-dropbox: webupd8team/nemo3/ubuntu
nemo-fileroller: webupd8team/nemo3/ubuntu
nemo-media-columns: webupd8team/nemo3/ubuntu
numix-folders: noobslab/icons/ubuntu
numix-gtk-theme: noobslab/themes/ubuntu
numix-icon-theme: noobslab/icons/ubuntu
numix-icon-theme-circle: noobslab/icons/ubuntu
numix-icon-theme-square: noobslab/icons/ubuntu
psensor: jfi/ppa/ubuntu
psensor-common: jfi/ppa/ubuntu
python-nemo: webupd8team/nemo3/ubuntu
scribus-ng: scribus/ppa/ubuntu
scribus-ng-data: scribus/ppa/ubuntu
scribus-ng-doc: scribus/ppa/ubuntu
simplescreenrecorder: maarten-baert/simplescreenrecorder/ubuntu
simplescreenrecorder-lib: maarten-baert/simplescreenrecorder/ubuntu
smplayer: mc3man/xerus-media/ubuntu
smplayer-themes: mc3man/xerus-media/ubuntu
smtube: mc3man/xerus-media/ubuntu
tlp: linrunner/tlp/ubuntu
tlp-rdw: linrunner/tlp/ubuntu
tp-smapi-dkms: linrunner/tlp/ubuntu # TLP Power Management, for Lenovo ThinkPad laptop
uget: plushuang-tw/uget-stable/ubuntu
va-driver-all: mc3man/mpv-tests/ubuntu
veracrypt: unit193/encryption/ubuntu
vlc: mc3man/xerus-media/ubuntu
vlc-data: mc3man/xerus-media/ubuntu
vlc-l10n: mc3man/xerus-media/ubuntu
vlc-plugin-base: mc3man/xerus-media/ubuntu
vlc-plugin-notify: mc3man/xerus-media/ubuntu
vlc-plugin-qt: mc3man/xerus-media/ubuntu
vlc-plugin-samba: mc3man/xerus-media/ubuntu
vlc-plugin-skins2: mc3man/xerus-media/ubuntu
vlc-plugin-video-output: mc3man/xerus-media/ubuntu
vlc-plugin-video-splitter: mc3man/xerus-media/ubuntu
vlc-plugin-visualization: mc3man/xerus-media/ubuntu
vokoscreen: mc3man/xerus-media/ubuntu
xapps-common: webupd8team/nemo3/ubuntu
zulucrypt-cli: hda-me/zulucrypt/ubuntu
zulucrypt-gui: hda-me/zulucrypt/ubuntu
LarryWilson
  • 71
