When I plug my 1-terabyte Seagate hard drive in a USB port on my desktop PC, it mounts NTFS filesystem /dev/sdc1 successfully but fails to mount ext filesystem /dev/sdc2 because of an apparent error loading the filesystem journal.
Here is what appears in /var/log/syslog during the few seconds after I plug the drive in:
Jun 24 20:48:11 somehost kernel: [6670321.891087] usb 1-1.2: new high-speed USB device number 44 using ehci-pci
Jun 24 20:48:11 somehost kernel: [6670322.010683] usb 1-1.2: New USB device found, idVendor=0bc2, idProduct=2332
Jun 24 20:48:11 somehost kernel: [6670322.010689] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jun 24 20:48:11 somehost kernel: [6670322.010693] usb 1-1.2: Product: Portable
Jun 24 20:48:11 somehost kernel: [6670322.010696] usb 1-1.2: Manufacturer: Seagate
Jun 24 20:48:11 somehost kernel: [6670322.010699] usb 1-1.2: SerialNumber: 2GHH43FZ
Jun 24 20:48:11 somehost mtp-probe: checking bus 1, device 44: "/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2"
Jun 24 20:48:11 somehost mtp-probe: bus: 1, device: 44 was not an MTP device
Jun 24 20:48:11 somehost kernel: [6670322.011257] usb-storage 1-1.2:1.0: USB Mass Storage device detected
Jun 24 20:48:11 somehost kernel: [6670322.011309] scsi50 : usb-storage 1-1.2:1.0
Jun 24 20:48:12 somehost kernel: [6670323.011231] scsi 50:0:0:0: Direct-Access     Seagate  Portable         SF04 PQ: 0 ANSI: 4
Jun 24 20:48:12 somehost kernel: [6670323.011508] sd 50:0:0:0: Attached scsi generic sg3 type 0
Jun 24 20:48:12 somehost kernel: [6670323.012501] sd 50:0:0:0: [sdc] 1953525164 512-byte logical blocks: (1.00 TB/931 GiB)
Jun 24 20:48:12 somehost kernel: [6670323.014587] sd 50:0:0:0: [sdc] Write Protect is off
Jun 24 20:48:12 somehost kernel: [6670323.014591] sd 50:0:0:0: [sdc] Mode Sense: 1c 00 00 00
Jun 24 20:48:12 somehost kernel: [6670323.017357] sd 50:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jun 24 20:48:12 somehost kernel: [6670323.059605]  sdc: sdc1 sdc2
Jun 24 20:48:12 somehost kernel: [6670323.124689] sd 50:0:0:0: [sdc] Attached SCSI disk
Jun 24 20:48:15 somehost kernel: [6670325.576840] end_request: critical target error, dev sdc, sector 0
Jun 24 20:48:15 somehost kernel: [6670325.576848] JBD2: recovery failed
Jun 24 20:48:15 somehost kernel: [6670325.576852] EXT4-fs (sdc2): error loading journal
Jun 24 20:48:16 somehost ntfs-3g[508]: Version 2013.1.13AR.1 external FUSE 29
Jun 24 20:48:16 somehost ntfs-3g[508]: Mounted /dev/sdc1 (Read-Write, label "Expansion Drive", NTFS 3.1)
Jun 24 20:48:16 somehost ntfs-3g[508]: Cmdline options: rw,nosuid,nodev,uhelper=udisks2,uid=1000,gid=1000,dmask=0077,fmask=0177
Jun 24 20:48:16 somehost ntfs-3g[508]: Mount options: rw,nosuid,nodev,uhelper=udisks2,allow_other,nonempty,relatime,default_permissions,fsname=/dev/sdc1,blkdev,blksize=4096
Jun 24 20:48:16 somehost ntfs-3g[508]: Global ownership and permissions enforced, configuration type 7
Jun 24 20:48:16 somehost udisksd[2934]: Mounted /dev/sdc1 at /media/ps/Expansion Drive on behalf of uid 1000
In this case, the sdc2 partition is inaccessible, but other times, it gets mounted successfully, except that it is read-only, and I see this:
Jun 24 20:56:21 somehost kernel: [6670811.293826] EXT4-fs (sdc2): warning: mounting fs with errors, running e2fsck is recommended
Jun 24 20:56:21 somehost kernel: [6670811.295543] EXT4-fs (sdc2): mounted filesystem with ordered data mode. Opts: (null)
Jun 24 20:56:21 somehost udisksd[2934]: Mounted /dev/sdc2 at /media/ps/f9940392-a20f-461d-a7c3-6c1132acf20b on behalf of uid 1000
Jun 24 20:56:26 somehost kernel: [6670816.539506] end_request: critical target error, dev sdc, sector 1218352432
Jun 24 20:56:26 somehost kernel: [6670816.539518] Aborting journal on device sdc2-8.
When I try "touch foobar" in the sdc2 mount point, I get "cannot touch ‘foobar’: Read-only file system".
I plugged this same drive on a ChromeBook, and the sdc2 partition is successfully mounted as read-write, and I can create files on it.
Back on the PC, I tried "e2fsck/dev/sdc2" and got this:
e2fsck 1.42.9 (4-Feb-2014)
/dev/sdc2: recovering journal
/dev/sdc2 contains a file system with errors, check forced.
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/sdc2: 2131785/45793280 files (0.2% non-contiguous), 128417943/183154845 blocks
When I mount the partitions again, I still get this:
Jun 24 21:05:44 somehost kernel: [6671374.212541] end_request: critical target error, dev sdc, sector 1218352432
Jun 24 21:05:44 somehost kernel: [6671374.212568] Aborting journal on device sdc2-8.
fdisk says this:
Disk /dev/sdc: 1000.2 GB, 1000204883968 bytes
255 heads, 63 sectors/track, 121601 cylinders, total 1953525164 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0xa03cb026
   Device Boot      Start         End      Blocks   Id  System
/dev/sdc1              63   488281367   244140652+   7  HPFS/NTFS/exFAT
/dev/sdc2       488281368  1953520127   732619380   83  Linux
This problem did not happen before I upgraded Ubuntu from 12.04 to 14.04, but that is likely a coincidence.
Questions:
  1. Could this be a hardware problem with the drive?
  2. Should I try e2fsck with any command-line options to force it to fix the problem, if possible?
  3. Is the only solution to reformat sdc2 (with mke2fs)? (The data is not very important, as it is a bunch of backups.)
Thanks.
