Is there any way to resize these app icons in Ubuntu 18.04?
They seem too big to me.
gnome dash icons
pomsky
  • 70,557
noobie
  • 73
  1. You can edit /usr/share/gnome-shell/theme/gnome-shell.css.
    Don't forget to make a backup of the original file!
  2. Search for a line starting with #dash {.
  3. In the following lines you can change the properties like .icon-grid { spacing and icon-grid .overview { icon-size.
  4. After your changes you have to restart the Gnome Shell with Alt+F2 and typing r and Enter.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
abu_bua
  • 11,313
Thanks for this info. On my system 18.04 I have found you only need change /usr/share/gnome-shell/theme/ubuntu.css
And only the line:
/* App Vault/Grid */
.icon-grid {
  spacing: 30px;
  -shell-grid-horizontal-item-size: 96px; /* change this line - was 136px */
  -shell-grid-vertical-item-size: 136px; }
  .icon-grid .overview-icon {
    icon-size: 96px; }
karel
  • 122,292
  • 133
  • 301
  • 332
Dave
  • 113
I just managed to change the size in Ubuntu 20.04.1. When using a custom theme the .css is in that file. So Home/.themes.
I changed:
  • shell-grid-horizontal-item-size: 86 px
  • shell-grid-vertical-item-size: 60 px;
    With the same number the icons are out of shape.
I use the gnome extension for 10 columns. So much better !!!
Two things:
  1. The file to edit might be /usr/share/gnome-shell/theme/ubuntu.css, not gnome-shell.css. At least this is my case for a fresh Ubuntu 18.04 install.
  2. You are still "stuck" with a max of 6 columns. If you want more, then use the "More columns in applications view" extension: https://extensions.gnome.org/extension/1305/more-columns-in-applications-view/
EQrqtze
  • 106
