I was using Ubuntu 17.04 and had to install some packages but I was encountering some errors(like Error 404) and I wasn't also able to update apt-get so I followed this online tutorial and made some changes in the sources.list after which I was able to update apt-get and install the packages. However on restarting my PC now it directly goes to Windows 10 without showing the bootloader like it used to do
You cannot get back into Linux ?
Is Windows located on a separated hard-disk ?
You could re-install with 18.04 LTS in expert-modus - but only re-install the root-files in the root-partition of '/' - and do not format the previous /home - Partition of your linux and also do not format the windows-Partition. This way grub will be reinstalled too (into MBR of sda? - or into MBR of root-harddisk) and update-grub2 will be done automatically.
This way Windows will be accepted and your previous Linux-/home partition will be taken over.
dschinn1001
  • 3,863
