I want Ubuntu to get the hostname and DNS name from a DHCP client. The default installation of UbuntuĀ 11.10 (Oneiric Ocelot) does not do that.
The same question was asked and is unsolved on Ubuntu Forums.
Oli's answer is demonstrably false ("You don't get your hostname from the DHCP server"), as evidenced by the other answers here, and also by my recent experience on a RHEL7 system. Said system got its host name from the DHCP server.
And, indeed, there are things in the DHCP configuration files that are supposed to make it happen. For example:
host host4 { # verified
hardware ethernet 41:88:22:11:33:22;
fixed-address 192.168.0.4;
option host-name "host4";
Is supposed to tell that host that his name is host4.
As it turns out, isc's dhclient DOES NOT APPEAR TO SUPPORT THIS!
However, dhcpcd5 does, out of the box. Stop dhclient, install dhcpcd5, run dhcpcd, renew your lease, and poof, your hostname on your DHCP client is set to the name sent from the DHCP server. No dhclient-exit-hooks.d scripting, no hacks in rc.local, nothing.
As an end-note, I've spent a lot of time trying to get this to work using ISC's dhclient. Absolutely no joy, even when the server sends the host name.
My initial solution to the problem was writing some cute code in rc.local to detect when the network came up and forcing a (in my case) search of /etc/hosts to get the hostname and then running hostname with that host name. It works, but until the network comes up your hostname is probably wrong (when first deploying a host, I remove /etc/hostname, so the host name is localhost until I can run /etc/init.d/hostname.sh start once the network comes up - so when first getting a new name you need to boot twice - once to get your hostname, and once to have that name available when everything starts up...).
Note that when using Ubuntu 18.04 the tie-in scripts are no longer necessary. If the hostname of the install is set to localhost in /etc/hostname the DHCP client will set the hostname automatically at startup using the name issued by DHCP, if present. When running hostnamectl it will list localhost as the permanent hostname, and whatever DHCP issues as a transient hostname.
testaccount@dhcp-hostname:~$ hostnamectl
Static hostname: localhost
Transient hostname: dhcp-hostname
There is a way to do it with a little script for a dhcp hook as described here.
Create a new file:
sudoedit /etc/dhcp/dhclient-exit-hooks.d/hostname
and paste the following code:
#!/bin/sh
# Filename: /etc/dhcp/dhclient-exit-hooks.d/hostname
# Purpose: Used by dhclient-script to set the hostname of the system
# to match the DNS information for the host as provided by
# DHCP.
# Do not update hostname for virtual machine IP assignments
if [ "$interface" != "eth0" ] && [ "$interface" != "wlan0" ]
then
return
fi
if [ "$reason" != BOUND ] && [ "$reason" != RENEW ] \
&& [ "$reason" != REBIND ] && [ "$reason" != REBOOT ]
then
return
fi
echo dhclient-exit-hooks.d/hostname: Dynamic IP address = $new_ip_address
hostname=$(host $new_ip_address | cut -d ' ' -f 5 | sed -r 's/((.*)[^\.])\.?/\1/g' )
echo $hostname > /etc/hostname
hostname $hostname
echo dhclient-exit-hooks.d/hostname: Dynamic Hostname = $hostname
Replace eth0 and wlan0 with the names of the interfaces from which you want to obtain the hostname. In most cases eth0 and wlan0 should stay the same.
Make sure it is readable...
chmod a+r /etc/dhcp/dhclient-exit-hooks.d/hostname
That's all. On the next dhcp response your hostname will update automatically.
You can get your hostname from your DHCP server - it is part of the DHCP specification.
https://www.rfc-editor.org/rfc/rfc1533#section-3.14
"This option specifies the name of the client"
d_inevitable's answer almost solved my problem, but not completely. The problem was that although:
The DHCP server was sending a hostname (by adding the
option host name 'client1'
in the dhcpd.conf) and I actually verified it by capturing and analyzing the contents of the DHCP offer with wireshark
The DHCP client was expecting the hostname from DHCP server (by adding
request host-name
in the dhclient.conf)
The client was not getting a new hostname (easily verified by typing
hostname
in terminal and getting the old hostname, or no hostname if I had deleted the contents/file). As a result, the proposed solution by d_inevitable was only copying an empty string.
To solve that, I applied a crud solution, that generally should not be followed unless you are desperate to make it work, like I was.
First, open with edit capability the DHCP client control script:
sudo vi /sbin/dhclient-script
There, you will have to locate the function
set_hostname()
Just use the search and it should come right up. Now, at least on my computer, this function has three if-then-else conditions, encapsulated to each other:
# set host name set_hostname() { local current_hostname
if [ -n "$new_host_name" ]; then current_hostname=$(hostname) # current host name is empty, '(none)' or 'localhost' or differs from new one from DHCP if [ -z "$current_hostname" ] || [ "$current_hostname" = '(none)' ] || [ "$current_hostname" = 'localhost' ] || [ "$current_hostname" = "$old_host_name" ]; then if [ "$new_host_name" != "$old_host_name" ]; then hostname "$new_host_name" fi fi fi }
Now, what you need is to force the assignment of the new hostname to your host, no matter what. Therefore you want to comment out the two encapsulated if-then-else. The result should look something like:
if [ -n "$new_host_name" ]; then current_hostname=$(hostname) # current host name is empty, '(none)' or 'localhost' or differs from new one from DHCP #if [ -z "$current_hostname" ] || # [ "$current_hostname" = '(none)' ] || # [ "$current_hostname" = 'localhost' ] || # [ "$current_hostname" = "$old_host_name" ]; then # if [ "$new_host_name" != "$old_host_name" ]; then hostname "$new_host_name" # fi #fi fi }
Now the d_inevitable's or this should work as expected. Hope that helps if you are in a similar desperate frustration as I was.
The answer depends on whether or not you are using static leases on your DHCP server. If you are, it is unnecessary to get the hostname from DNS. You can change this line in d_inevitable's solution
hostname=$(host $new_ip_address | cut -d ' ' -f 5)
to
hostname=${new_host_name}
But this should happen automatically if your hostname is originally set to localhost.localdomain, so you don't have to write a script. However, if you want to set the hostname to the FQDN, you'll need to change d_inevitable's script to
hostname=${new_host_name}.${new_domain_name}
Again, all this only works if you're using static leases.
If found that can be a dhcpclient scripts bug. http://blog.schlomo.schapiro.org/2013/11/setting-hostname-from-dhcp-in-debian.html
Try to clean $old_host_name on ip renew
echo unset old_host_name > /etc/dhcp/dhclient-enter-hooks.d/unset_old_hostname
Also static /etc/hostname seems to has prority over dhcp answer so leave it empty
> /etc/hostname
Tested on ubuntu 14.04 and dnsmasq server.
You don't get your hostname from the DHCP server.
You can send your hostname to the server, which may change the IP you're assigned. You can change what name is sent either by editing your Network Manager connection (the field is called DHCP Client ID) or you can edit (as root) /etc/dhcp/dhclient.conf. Look for the line that says:
send host-name "<hostname>";
... and change <hostname> to whatever you like.
By default Ubuntu will get its DNS settings from the router (if it sends them) but I suspect you're talking about local DNS/mDNS where you can access other computers by their hostname. This is called Ahavi or Zeroconf in Ubuntu and it's installed by default.
You should be able to access your computer by <hostname>.local
First get an IP address for your client from your DHCP server, then you'll find the client hostname in /var/lib/dhcp/dhcpd.leases looks for the client-hostname entries. HTH
Don't have enough reputation to comment, but I'd like to piggy-back on the previous answer as it almost solved the problem for me using a dhclient hook.
I've found that using the standard ISC DHCP Server for some reason, the aforementioned hook outputs a host name with a '.' period character at the end of the hostname for some reason.
So, in the previous answer you might need "cut out" the extraneous period with a sed:
Would become:
hostname=$(host $new_ip_address | cut -d ' ' -f 5 | sed -e "s/\.$//g")
