I have many Ubuntu-powered devices around me.
As far I know /etc/group, /etc/passwd, /etc/shadow are created during installation, so they do not belong to any package:
$ dpkg -S /etc/passwd
dpkg-query: no path found matching pattern /etc/passwd
$ dpkg -S /etc/shadow
dpkg-query: no path found matching pattern /etc/shadow
$ dpkg -S /etc/group
dpkg-query: no path found matching pattern /etc/group
My question is in title - How to check that my users and groups are correct? What if I misspelled or changed something by hand in such files?
muru
  • 207,228
N0rbert
  • 103,263
1. Basic approach
I found very useful package for such operation. It is named base-passwd and has the following description:
$ apt-cache show base-passwd
Package: base-passwd
Description-en: Debian base system master password and group files
 These are the canonical master copies of the user database files
 (/etc/passwd and /etc/group), containing the Debian-allocated user and
 group IDs. The update-passwd tool is provided to keep the system databases
 synchronized with these master files.
Master files (in aforementioned terminology) are placed in:
  • /usr/share/base-passwd/group.master
  • /usr/share/base-passwd/passwd.master
The package contains only one binary /usr/sbin/update-passwd.
Its purpose is described in man-page (man update-passwd):
DESCRIPTION
update-passwd handles updates of /etc/passwd, /etc/shadow and /etc/group on running Debian systems. It compares the current files to master copies, distributed in the base-passwd package, and updates all entries in the global system range (that is, 0–99).
For the problem from the question we need to run:
sudo update-passwd --sanity-check --verbose
Also you can try to run the simulation (dry-run):
$ sudo update-passwd --sanity-check --verbose --dry-run
Reading passwd from /usr/share/base-passwd/passwd.master
Reading group from /usr/share/base-passwd/group.master
Reading passwd from /etc/passwd
Reading shadow from /etc/shadow
Reading group from /etc/group
Running without arguments will safely update /etc/passwd, /etc/shadow and /etc/group or quit quietly:
$ sudo update-passwd --verbose
No changes needed
The utility covers 39 standard groups - adm, audio, backup, bin, cdrom, daemon, dialout, dip, disk, fax, floppy, games, gnats, irc, kmem, list, lp, mail, man, news, nogroup, operator, plugdev, proxy, root, sasl, shadow, src, staff, sudo, sys, tape, tty, users, utmp, uucp, video, voice, www-data.
One can read local documentation about standard groups in /usr/share/doc/base-passwd/users-and-groups.html (or online).
2. Deeper approach
Warning: do not continue if unsure what you are doing or if you are newbie.
Start with
and then if you have installed other software from repositories and then trashed your /etc/passwd and/or /etc/group you can try to reinstall all such packages with the command based on @muru suggestion:
sudo apt-get install --reinstall \
$(grep -RlE '(getent|useradd|adduser|groupadd|addgroup|chrgp|chmod|gpasswd|usermod)' \
/var/lib/dpkg/info --include='*inst' | sed -r 's:.*/(.*)\.[-a-z]+inst:\1:')
2.1. Broken /etc/group
If you have removed entries from /etc/group you will face error messages as
dpkg: unrecoverable fatal error, aborting:
 unknown group 'crontab' in statoverride file
E: Sub-process /usr/bin/dpkg returned an error code (2)
You need to remove corresponding lines from /var/lib/dpkg/statoverride and /etc/passwd then try again with the command above.
Other possible error message is
E: Internal Error, No file name for dbus:amd64
You can fix it by downloading the package manually:
apt-get download dbus
sudo dpkg -i dbus*.deb
and then try again with the command above.
If you have removed systemd-related groups systemd-journal, systemd-timesync, systemd-network, systemd-resolve, systemd-bus-proxy from /etc/group then remove them from /etc/passwd and reinstall systemd package with
sudo apt-get install --reinstall systemd
2.2. Broken /etc/passwd
If you have removed entries from /etc/passwd you will face error messages as
 unknown user 'hplip' in statoverride file
You need to remove corresponding line from /var/lib/dpkg/statoverride and then try again with the command above.
N0rbert
  • 103,263
