Disable Lock Screen
You can disable the lock screen permanently when waking from suspend.
First use this command to discover current settings:
$ gsettings get org.gnome.desktop.lockdown disable-lock-screen
false
Now set it to true using this command:
gsettings set org.gnome.desktop.lockdown disable-lock-screen 'true'
If you are unhappy with the new setting you can reverse it using:
gsettings set org.gnome.desktop.lockdown disable-lock-screen 'false'
Disable Screen Saver Locking
There was some confusion where people think disabling the Lock screen also disables the screen saver which is invoked after a certain period of inactivity. The screen saver requires input to get your desktop back. Some people may want the screen saver to come on but not have it locked when waking up the screen.
To check screen saver lock status use:
$ gsettings get org.gnome.desktop.screensaver lock-enabled
true
If true you can turn off screen saver locking with:
gsettings set org.gnome.desktop.screensaver lock-enabled false
To reverse the setting back use:
gsettings set org.gnome.desktop.screensaver lock-enabled true
In Gnome screen locking guide it says:
6.2. Screen Locking
By default, GNOME Power Manager supports a simple locking scheme. This
means that the screen will lock if set to Lock screen in
gnome-screensaver when the lid is closed, or the system performs a
suspend or hibernate action.
There is a complex locking scheme available for power users that
allows locking policy to change for the lid, suspend and hibernate
actions. To enable this complex mode, you will have to disable the
GConf key:
/apps/gnome-power-manager/lock/use_screensaver_settings
Then the policy keys can be set to force a gnome-screensaver lock
and unlock when the action is performed:
/apps/gnome-power-manager/lock/blank_screen
/apps/gnome-power-manager/lock/suspend
/apps/gnome-power-manager/lock/hibernate
