20
I have a folder with 40 GB of dozens of directories and stuff, and I want to see the exact size of the root folder in bytes ..
I have tried using this, but it shows the size in kilobytes:
du -s foldername
Ahmad
  • 1,261
Use the -B1 parameter to du:
du -s -B1 foldername
$ man 1 du
 -B, --block-size=SIZE
          use SIZE-byte blocks
You could also try the --apparent-size flag
knittl
  • 1,162
du - estimate file space usage
          scale sizes by SIZE before printing them.  E.g., '-BM' prints sizes in units of 1,048,576 bytes.  See SIZE format below.
-b, --bytes
          equivalent to '--apparent-size --block-size=1'
For Example,
user$ du -B1 filename
du -sb foldername
seems to do the trick
