I have a dell laptop that i just installed Ubuntu server 18.04 LTS on, and that i'm using as a Plex / TVHeadend server. I'd like to stop the laptop from going to sleep when the lid/laptop screen is closed, but still allow the screen to shut off.
Currently I modified /etc/systemd/login.conf and set
HandleLidSwitch=ignore
The only problem is that now the screen never shuts off when the lid is closed. Since this will be left running 24/7, i'd like the screen to shut off so as not to generate extra heat and save on power
Any suggestions?
/etc/systemd/logind.conf
"Uncomment" the following keys and change it's values to ignore :
HandleSuspendKey=ignore
HandleLidSwitchDocked=ignore
then restart the service with
sudo systemctl restart systemd-logind
Worked for me even when it's on battery.
alfx
  • 506
How about installing gnome-tweaks and doing this with a GUI?
Run apt-get install gnome-tweaks in a terminal, launch Gnome tweaks, and go to the power section in the GUI and disabling suspend when laptop lid is closed
Shadi
  • 131
After all this time I finally figured it out
Since Ubuntu 18.04 doesn't have a /etc/rc.local file by default we need to create one.
sudo vi /etc/rc.local
press i to enter insert mode
Type the following 3 lines
#!/bin/bash
setterm --blank 1
exit 0
Next press escape, then type :wq to save and quit vi
Now change the permissions so the file can execute
sudo chown root /etc/rc.local
sudo chmod 755 /etc/rc.local
now restart the rc-local service. Type the following
systemctl restart rc-local
I have had the same issue and no luck trying to search online. Past Ubuntu versions had this option available iirc, but it seems 18.04 does not...
Currently, my workaround is to set blank screen to some time interval, and then just shut my computer lid (with the same HandLidSwitch=ignore setting), then let time pass until it auto-blanks the screen by itself. However this isn't exactly convenient and prevents you from having your own settings for how long screen blanking takes (for example, I prefer that my screen never blanks during idle usage - not compatible with this workaround).
Overall, Ubuntu 18.04's settings for sleeping your computer / blanking the screen seem very cumbersome... there doesn't seem to me to be a way to manually suspend / sleep my computer if I've changed the lid-close functionality, for example.
Stephen Rauch
  • 1,156
  • 15
