Is there a way to emulate a Windows CMD in Linux. What i need is full functionality as if I use the real CMD running in Windows. I want to be able to practice tutorials about WIN CMD, using my Linux PC.
Searching the Internet didn't help a lot.
Thanks for your help :-)
Edit:
Thank you for all your answers. I really appreciated your time spending. I mostly wanted to practice WMIC commandline using my main computer running under Ubuntu. I tried most of the solutions proposed but what worked better was virtualBox ;-)
  1. Have you tried using wine for this? This isn't running natively through your box, but rather through a compatibility layer. As user535733 stated, "full functionality" is a very difficult term, windows is windows for a reason, and they're not releasing their source code any time soon. Most commands on "cmd" should work in the wine version, but maybe not all: https://wiki.winehq.org/Cmd
  2. Alternatively, you can use the FOSS "Powershell" for this. It has/should have the same syntax as the windows equivalent. Someone online forked the original windows program: https://github.com/powershell/powershell
  3. And ultimately, the only other way i can think of having (near) native cmd/powershell is via gpu passthrough. Be warned, this is a difficult process. It all depends on what functionality you require out of your cmd/powershell environment.
If none of these fulfil your needs, consider dual booting with windows, or continue with your search.
DosBox is a full emulator for x86 with a DOS-compatible command-line OS built-in and good support for DOS programs, including games which required VGA (or EGA/CGA) graphics.
So you can write batch programs and run DOS utilities etc.
It's not clear from your question whether you wanted to be able to run Windows programs - if so, DOSBox won't help and you'll need something like Wine.
thomasrutter
  • 37,804
