I have installed apache2 , php7.2.5 and mysql-server and also install phpmyadmin. Apache2 , php and mysql are running well. But when i try to run phpmyadmin , it displays a bunch of code in the browser. Looks like this:
<?php
/* vim: set expandtab sw=4 ts=4 sts=4: */
 * Main loader script
 * @package PhpMyAdmin
 * Gets some core libraries and displays a top message if required
require_once 'libraries/common.inc.php';
 * display Git revision if requested
require_once 'libraries/display_git_revision.lib.php';
require_once 'libraries/Template.class.php';
 * pass variables to child pages
$drops = array(
    'lang',
    'server',
    'collation_connection',
    'db',
    'table'
foreach ($drops as $each_drop) {
    if (array_key_exists($each_drop, $_GET)) {
        unset($_GET[$each_drop]);
unset($drops, $each_drop);
Help me to fix this problem.
Thanks
abu_bua
  • 11,313
lathhik
  • 41
I had the same problem and I used the following command:
sudo apt-get install libapache2-mod-php
If it doesn't resolve your problem, uninstall php and everything associated with it as described in this answer, using the command:
sudo apt-get purge 'php*'
after that reinstall php with the command:
sudo apt-get install php
Nmath
  • 12,664
