I have installed Ubuntu 18.04 using the windows store and i started using them but I have a glitch. I'm unable to install any package and the terminal keeps returning these errors.
Ubuntu Terminal error description
It reads the package but provides an error stating
Error Unable to locate the package[package-name]
Some of the errors are
The following packages will be upgraded:
ebtables
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
62 not fully installed or removed.
Need to get 0 B/79.9 kB of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 28484 files and directories currently installed.)
Preparing to unpack .../ebtables_2.0.10.4-3.5ubuntu2.18.04.1_amd64.deb ...
invoke-rc.d: could not determine current runlevel
* Error: insufficient privileges to access the ebtables rulesets.
invoke-rc.d: initscript ebtables, action "stop" failed.
dpkg: warning: old ebtables package pre-removal script subprocess returned error exit status 1
dpkg: trying script from the new package instead ...
dpkg: error processing archive /var/cache/apt/archives/ebtables_2.0.10.4-3.5ubuntu2.18.04.1_amd64.deb (--unpack):
new ebtables package pre-removal script subprocess returned error exit status 1
update-rc.d: warning: start and stop actions are no longer supported; falling back to defaults
root@DESKTOP-SJPLLRG:~#
Is there any solution that would allow us to solve this issue?
