I know that this is a common problem and i have tried many "fixes" but none of them worked.
I want to install an update to one of my programs, but i can't because it says that I have unmet dependencies. I used sudo apt install -f and I got E: Sub-process /usr/bin/dpkg returned an error code (1) in detail:
Reading package lists... 0%
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
dkms gcc-5-base:i386 grub-efi-amd64-bin libbsd0:i386 libdrm-amdgpu1:i386 libdrm-nouveau2:i386 libdrm-radeon1:i386 libdrm2:i386 libedit2:i386 libelf1:i386 libexpat1:i386 libffi6:i386 libllvm4.0
libllvm5.0:i386 libqmi-glib1 libsensors4:i386 libstdc++6:i386 libvdpau1:i386 libx11-6:i386 libx11-xcb1:i386 libxau6:i386 libxcb-dri2-0:i386 libxcb-dri3-0:i386 libxcb-glx0:i386
libxcb-present0:i386 libxcb-sync1:i386 libxcb-xfixes0:i386 libxcb1:i386 libxdamage1:i386 libxdmcp6:i386 libxext6:i386 libxfixes3:i386 libxshmfence1:i386 libxxf86vm1:i386 linux-headers-4.4.0-101
linux-headers-4.4.0-101-generic linux-headers-4.4.0-103 linux-headers-4.4.0-103-generic linux-headers-4.4.0-104 linux-headers-4.4.0-104-generic linux-headers-4.4.0-108
linux-headers-4.4.0-108-generic linux-headers-4.4.0-119 linux-headers-4.4.0-119-generic linux-headers-4.4.0-87 linux-headers-4.4.0-87-generic linux-image-4.4.0-101-generic
linux-image-4.4.0-103-generic linux-image-4.4.0-104-generic linux-image-4.4.0-108-generic linux-image-4.4.0-119-generic linux-image-4.4.0-87-generic linux-image-extra-4.4.0-101-generic
linux-image-extra-4.4.0-103-generic linux-image-extra-4.4.0-104-generic linux-image-extra-4.4.0-108-generic linux-image-extra-4.4.0-119-generic linux-image-extra-4.4.0-87-generic
linux-signed-image-4.4.0-101-generic linux-signed-image-4.4.0-103-generic linux-signed-image-4.4.0-104-generic linux-signed-image-4.4.0-108-generic linux-signed-image-4.4.0-119-generic
linux-signed-image-4.4.0-87-generic mesa-vdpau-drivers:i386 mokutil shim vdpau-driver-all:i386
Use 'apt autoremove' to remove them.
The following additional packages will be installed:
linux-image-4.4.0-119-generic linux-image-4.4.0-127-generic
Suggested packages:
fdutils linux-doc-4.4.0 | linux-source-4.4.0 linux-tools
The following NEW packages will be installed:
0 upgraded, 2 newly installed, 0 to remove and 177 not upgraded.
30 not fully installed or removed.
Need to get 0 B/44.1 MB of archives.
After this operation, 136 MB of additional disk space will be used.
(Reading database ... 603843 files and directories currently installed.)
Preparing to unpack .../linux-image-4.4.0-119-generic_4.4.0-119.143_amd64.deb ...
Examining /etc/kernel/preinst.d/
run-parts: executing /etc/kernel/preinst.d/intel-microcode 4.4.0-119-generic /boot/vmlinuz-4.4.0-119-generic
Done.
Unpacking linux-image-4.4.0-119-generic (4.4.0-119.143) ...
dpkg: error processing archive /var/cache/apt/archives/linux-image-4.4.0-119-generic_4.4.0-119.143_amd64.deb (--unpack):
cannot copy extracted data for './boot/abi-4.4.0-119-generic' to '/boot/abi-4.4.0-119-generic.dpkg-new': failed to write (No space left on device)
No apport report written because the error message indicates a disk full error
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Examining /etc/kernel/postrm.d .
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 4.4.0-119-generic /boot/vmlinuz-4.4.0-119-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 4.4.0-119-generic /boot/vmlinuz-4.4.0-119-generic
Preparing to unpack .../linux-image-4.4.0-127-generic_4.4.0-127.153_amd64.deb ...
run-parts: executing /etc/kernel/preinst.d/intel-microcode 4.4.0-127-generic /boot/vmlinuz-4.4.0-127-generic
Done.
Unpacking linux-image-4.4.0-127-generic (4.4.0-127.153) ...
dpkg: error processing archive /var/cache/apt/archives/linux-image-4.4.0-127-generic_4.4.0-127.153_amd64.deb (--unpack):
cannot copy extracted data for './boot/abi-4.4.0-127-generic' to '/boot/abi-4.4.0-127-generic.dpkg-new': failed to write (No space left on device)
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 4.4.0-127-generic /boot/vmlinuz-4.4.0-127-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 4.4.0-127-generic /boot/vmlinuz-4.4.0-127-generic
So after that i run: dpkg -a --configure and got this:
`subprocess installed post-installation script returned error exit status 1
linux-image-4.4.0-116-generic
linux-signed-image-4.4.0-127-generic
linux-signed-image-4.4.0-116-generic
linux-image-extra-4.4.0-116-generic
linux-image-extra-4.4.0-127-generic
linux-image-4.4.0-112-generic
friendly-recovery
linux-image-4.4.0-109-generic
linux-firmware
linux-signed-image-4.4.0-112-generic
linux-signed-image-generic
linux-image-extra-4.4.0-112-generic
linux-image-extra-4.4.0-109-generic
linux-signed-image-4.4.0-109-generic
linux-signed-generic
initramfs-tools
I really don't know what to do, this isn't the first time this happened, the last time it happened i just reinstalled the entire OS, however now with my PLEX libary reaching well over 7 TB, that is out of the question. Thanks in advance! :)
