There are multiple ways to open files or folders such as
gnome-open
see
xdg-open
gvfs-open
so... which should I use ?!
Zanna
  • 72,312
Saver
It would depend on how you want to open the file. The commands you mentioned in your question and specifics for handing the target in a specific way.
First, the gnome-open command isn't available by default in the Ubuntu repository. So it wouldn't be standard for the Ubuntu environment. If you had a very specific reason for using something non-standard for Ubuntu, that would be your special occasion to change from the standard.
xdg-open is a generic method for opening files from the commandline, as if it was being opening by a click from the file browser. The application or context of the file being opened would depend on what you have set as a default method for the file to be handled.
gvfs-open Is no longer a standard method in Ubuntu. It has been replaced with gio open (an argument of the gio app). It will have a limited number of methods for opening the destination. If the destination file is an execution file you would have to specify the program to execute it (which can also be done via the shebang file header).
While clicking on helloworld.sh or helloworld.pl will open the file as a program, opening it with gio open helloworld.sh will open it as a text file, not as an executional file.
The latter is a an example that it would depend on how you want the file to be opened, or how you want to use the file.
In this case, if you want to execute the file you would open it with one of these options:
$ bash helloworld.sh
$ ./helloworld.sh
The quick answer is that way to open a file would depend on how you want to open it.
L. D. James
  • 25,444
