I have a very large text file, and I want to select part of the text (range of lines. Example: from line 10000 to line 40000 and the text has 100 thousand lines). But I do not see any option in these editors (gedit, pluma, nemo) that allows me to make this selection (only "select all or Ctrl+A" option).
I would like to know how to do it and in case they do not allow, what other similar text editor (GUI) exists that allows me to make this selection.
thanks
Clarification:
I already know the alternatives in the command line. The answer I ask is only in the text editors mentioned (or in other similar ones, native Linux applications. Exclude "vim" or "nano".)
I have installed the additional plugins of gedit and pluma, but I also do not see that they have this possibility of selection
This option can be found in notepad++. I installed a clone called notepadqq, but it does not have this option
acgbox
  • 2,367
vim can certainly do this: in command mode, enter 10000G hit V then 40000G. VoilĂ , requested selection.
However, what do you want to do with the selection?
glenn jackman
  • 18,218
From the command line (one of several methods):
head -number_of_lines < file.txt > file.new
YMOZ
  • 125
-1
In sublime text:
Ctrl-G to go to the last line you want to select, by number.
Edit > Mark > Set Mark to set your selection-end marker.
Ctrl-G (or Ctrl-Home) to go to the first line you want to select.
Edit > Mark > Select to Mark
In vscode:
go to line should select text from the current cursor when holding down shift
acgbox
  • 2,367
