I've successfully installed runit via apt-get (at least I got no errors)
Setting up runit (2.1.2-9.2ubuntu1) ...
However, it seems runit isn't running itself, so to speak. Following command doesn't show anything.
ps -ef | grep runsvdir
I was able to run runsvdir manually on /etc/service and it seems to work because after that inside my services supervise folder appeared. But if I try to run
sudo sv status my-service
I receive
fail: my-service: runsv not running
I use runit to manage ruby on rails and sidekiq processes. Servers are Digital Ocean droplets. I have one server using Ubuntu 16.04 (which doesn't have this problem) and Ubuntu 18.04 (which have).
The first error I got after provisioning and deploy was actually
unable to open supervise/ok: file does not exist
I am wondering if these issues connected?
- Failed to connect to socket /com/ubuntu/upstart: Connection refused: Errors were encountered while processing: runit
- Will Ubuntu 18.04 LTS still support Upstart or do we have to change to systemd?
Thank you for your time!
